window issues.. passengerside
Old Dec 6, 2003 | 10:47 AM
BoostedH23a1's Avatar
Default window issues.. passengerside
well im about to go ape **** now.
like a month or 2 ago it went out and i figured out it was the master switch.. replaced that its all good.. now it dont work again.
looks like the same ****** pos problem. checked the wiring its all good. every fuse in the car is good. tested the regulator and it works fine.
wtf is this pos problem.
Old Dec 7, 2003 | 12:59 AM
user 9782082308's Avatar
Default Re: window issues.. passengerside (BoostedH23a1)
Does it work sometimes and other times it doesn't? To me it sound like the controler. Its a metal box about 4x5" in the front bottom of the driver side door. Open it up and look for fine cracks around the solder. Resolder and that should fix your problem.
Old Dec 7, 2003 | 07:16 PM
Default Re: window issues.. passengerside (racerx)
ahh ill check that out.. thx
Old Dec 7, 2003 | 07:46 PM
SKDRCR's Avatar
i know you probably checked this,
but if not, there is an on off switch on the drivers
side switch, sometimes you can accidently
flip that switch, causing the pass side window
to not work
Old Dec 12, 2003 | 12:47 PM
Default Re: window issues.. passengerside (SKDRCR)
haha ya i know its not that..
btw are u talking about the door lock box..
there isnt another box that i saw.. windows dont run thought that box
pldwelle
Sep 22, 2010 08:39 PM
tiptopEBPcivc
Apr 10, 2010 07:57 AM
SmoothLude
Jul 11, 2009 06:28 PM
PhantomLord
Audio / Security / Video
Apr 18, 2009 05:56 PM
basmasta7
Jul 22, 2003 10:07 PM
