Lock assembly in steering column
Old Dec 12, 2003 | 07:17 PM
Mach30SiR's Avatar
Default Lock assembly in steering column
ok so here it goes, i just got done putting in my EL gauges and went to start up the car, and guess what, they key wont kick back to on, so it keeps the starter engauged, and whats even more neato (sarcasm) is i can take out the key. So here we haev, a prelude, running, starter engauged, and no key. It takes alot of jiggling and stuff to get it to snap back to the on position. Is there a way i can lube this up or is the lock assembly shot to ****. also i know of a 93 Vtec lude around here with the assembly still in it ( junkyard) can i take that and have a key made for it?, and if so, will i have to have two different keys, one to get in the car, and one to start it?
thanks for the help
Old Dec 12, 2003 | 08:14 PM
rjr162's Avatar
Default Re: Lock assembly in steering column (Mach30SiR)
if you take the ignition switch from the other car, yes you would need two different keys (Think of the 80 and early to mid 90 GM's).
Try using some Tri-flow to see if it frees it up.
Old Dec 12, 2003 | 08:45 PM
Mach30SiR's Avatar
Default Re: Lock assembly in steering column (rjr162)
thats tri-flow?
Old Dec 13, 2003 | 06:09 AM
Mach30SiR's Avatar
where can i get tri-flow lubes, their site is useless.
runitup
21
Dec 26, 2020 05:17 PM
safedriver
May 25, 2012 02:48 AM
88 EF Hatch
Jun 27, 2009 06:52 PM
tampabitches
Aug 14, 2006 02:56 PM
themex77
Jun 19, 2006 08:05 PM
