Lights on Warning
Old Dec 27, 2003 | 06:21 PM
T-Mo's Avatar
Default Lights on Warning
I keep leaving my lights on and my warning chime thingy hasn't been working for a few months now. What should I check? Also I noticed that when a friend of mine checked my computer, the is a wire connector there that is not connected to anything. Could this be the problem?? After he did this, is when it started to Not work.
'92 Prelude Si
Old Dec 27, 2003 | 10:09 PM
speedracer9k's Avatar
maybe you should try to unplug it and see if it works then....just an idea
Old Dec 27, 2003 | 10:10 PM
92LudeSI's Avatar
plug the wire in and see what happens. Otherwise check the little switch in the door jam and make sure thats not stuck or something.
Old Dec 28, 2003 | 02:56 PM
T-Mo's Avatar
thats the problem. I do not see where the plug goes. I have been looking and I don't know where or what it goes to. That is why I was looking for help. The manual that I have doesn't show (or I couldn't find the info).
Old Dec 28, 2003 | 03:24 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: (T-Mo)
post some pictures...i need a visual....
Old Dec 28, 2003 | 08:53 PM
T-Mo's Avatar
Here's a couple of pics
Old Dec 29, 2003 | 06:06 AM
T-Mo's Avatar
bump...can the morning crew help me???
Old Dec 29, 2003 | 06:09 AM
Sephro's Avatar
Default Re: (T-Mo)
Does the dome light come on when you open the door?
Reason I am asking is thinking it might be the door sensor.
Could be the chimer (don't remember real name) IIRC it's located near the under dash fuse box.
Did it stop when your friend was messing with your ecu? Ask him what he did...
Old Dec 29, 2003 | 06:18 PM
T-Mo's Avatar
the dome light comes on. I haven't talked to the friend that did it in about a year. I haven't had a chimer since probably that long. I only noticed it didn't work when I left my lights on a couple of times and someone told me they were on.
Old Dec 29, 2003 | 06:57 PM
Zimmlude's Avatar
That plug looks aftermarket. I have a similar one on my aftermarket fog light harness.
Your chime might be toast, it is in the underdash fuse panel.
Old Dec 29, 2003 | 07:00 PM
T-Mo's Avatar
so its a fuse??
Old Dec 29, 2003 | 07:08 PM
TylerB's Avatar
Default Re: (T-Mo)
i had the same problem, my dome light and buzzer wasnt working. i had two blown fuses(wiper and interior lights), replaced them and it started working again
Old Dec 29, 2003 | 07:22 PM
T-Mo's Avatar
my interior fuse is good and I am assuming that the wiper one is good too since wipers are working (its raining here)
Old Dec 30, 2003 | 04:44 PM
T-Mo's Avatar
hello?? Should I just give up??
Old Jan 1, 2004 | 07:22 PM
T-Mo's Avatar
new year bump
tercelrcr
20
Nov 21, 2014 01:19 PM
mister.wong
Jan 27, 2008 12:41 AM
disposable
Sep 5, 2005 10:02 AM
robotosan
Apr 27, 2005 09:48 PM
