Gasket set
Old Jan 4, 2004 | 03:56 PM
Speedra500's Avatar
Default Gasket set
Hey, I am rebuilding my prelude engine with all aftermarket parts, and I want to replace all the seals and belts. Do any of you guys know any places that sell a complete gasket set for a reasonable price? And also do any of you guys know where I can find a thin headgasket for higher compression? Oh, and one more thing can anyone post a link for the automatic to manual tensioner conversion thanks
Old Jan 4, 2004 | 04:58 PM
Matgallis's Avatar
Default Re: Gasket set (Speedra500)
Personally I wouldn't go with a thinner head gasket. That would be the last thing I would go for to get higher compression. Just have the head shaved a slight amount if u aren't satisified with ur after market parts... but thats just me maybe some other guys have different opinions..
Old Jan 4, 2004 | 05:07 PM
Speedra500's Avatar
Default Re: Gasket set (92`Legend)
Well, I don't think there are any places locally that can mill the head, and I do not understand why buying a thin headgasket would be such a bad idea? You think it might not seal properly or break, I forgot to mention this is on a NA motor. I have the 11.0:1 type-s pistons and I was hoping to squeeze out a tiny bit higher numbers through a thinner head gasket
Old Jan 4, 2004 | 05:13 PM
Don Jefe's Avatar
Yeah, i would also like to know why getting a thinner headgasket wouldnt be a good idea. Is it something about durability? Longevity?
Old Jan 4, 2004 | 05:31 PM
Shakes's Avatar
space cadet
Default Re: (Hank the retard)
http://www.hondaautomotiveparts.com sells a gasket/seal kit.
Old Jan 4, 2004 | 05:57 PM
Matgallis's Avatar
Default Re: (shakes)
i'm not an expert or anything but it seems if you have a thinner you are more likely to have it blown it a shorter amount of time. Where do u live? Any machine shop will mill...
Old Jan 4, 2004 | 06:42 PM
Shakes's Avatar
space cadet
Default Re: (92`Legend)
he could always ask todd to take it to KMS for him lol.
Old Jan 4, 2004 | 07:57 PM
satan_srv's Avatar
you get the gasket set from honda. OEM.
Old Jan 4, 2004 | 08:05 PM
AndyD's Avatar
http://www.hondaautomotiveparts.com or http://www.slhonda.com
Old Jan 4, 2004 | 10:49 PM
Speedra500's Avatar
Default Re: Gasket set (AndyD)
Thanks everyone, I hope the block gasket set will come with most of the stuff I need, I already have a couple gaskets here and there, and the expensive full gasket set would come with a headgasket that I wouldnt use, and I will probably get one of those insulated intake manifold gaskets, see if they work
Old Jan 5, 2004 | 05:33 AM
lildrgn2.0's Avatar
New User
Hey Eric. I see you found HT.
Welcome.....
Old Jan 5, 2004 | 06:31 AM
PhazedSI's Avatar
I used a Fel-pro head set and bottom end gasket set
.::Lee::.
Feb 17, 2004 08:50 PM
Evs-One
Mar 3, 2003 01:09 AM
Import RP
Nov 8, 2001 05:32 PM
