help
Old Jan 1, 2004 | 09:41 AM
dazz...uk's Avatar
Default help
hi
i have a 97 base lude with a f20a engine,superchip,cold air intake,fse boost valve,.
when i put my foot down going up hill<around 80 mph> i somtimes here a rattle coming from my
valves.i have had the clearence checked everything ok,do you guys have any idea
what might cause this,may be timing or fueling ,
thank you
Old Jan 1, 2004 | 11:18 AM
noble4ws's Avatar
how do you have a 97 lude with a f20 engine
Old Jan 1, 2004 | 11:40 AM
satan_srv's Avatar
Default Re: (noble4ws)
he's in europe.
Old Jan 1, 2004 | 01:07 PM
goraiko's Avatar
Default Re: help (dazz...uk)
It could been pinking, especially if under load. Is it worse in hot weather? Try using super u/l to see if that helps. Is the engine/car modified at all? Oh yeah, check your timing try resetting the ecu as well as that may help.
Old Jan 2, 2004 | 12:30 AM
@ries's Avatar
Default Re: help (goraiko)
sounds like it might be detonation. check your spark-plugs
Old Jan 2, 2004 | 08:01 AM
dazz...uk's Avatar
Default Re: help (emoBB1)
thanks for replying,i use optimax all the time,i have just changed my plugs.i have just retared my timing a little it seems much better now,i think my superchip might
need remapping now,the rattle is much less so i must be on the right track
darren<uk>
Old Jan 2, 2004 | 02:29 PM
93ludeSi's Avatar
def sounds like det, what other mods do you have done to the car, if the chip is leaning you out too much, that might also be causing the pinging
Old Jan 3, 2004 | 04:12 AM
OTT's Avatar
OTT
Get rid of the FSE power boost valve, what a ripoff.
The stock fuel reg works better and if that regulater really coud give youBetter fuel economy and More power then dont you think they would be standard on every car!
I know someone else who had one and once he got shot of it he said it was like a new engine!
DelSolAntrax
Jan 8, 2014 04:51 PM
Ran4it2
Jun 11, 2009 11:46 PM
v8 integra
Other Make Vehicles
Sep 23, 2008 01:04 PM
blue89hatch
Apr 5, 2008 01:11 AM
integracivic94
Sep 6, 2003 04:47 AM
