timing question
Old Dec 27, 2003 | 01:13 PM
hatch4raceb16's Avatar
Default timing question
My friend has a newer lude, a 99 SH and he thinks he jumped the timing by a tooth or so, how do we check this? His car is an automatic if that makes a diff. thanks. I know i have to pull the timing belt cover and look at the arrows, but which way are they supposed to point?
Old Dec 27, 2003 | 01:29 PM
Shakes's Avatar
space cadet
Default Re: timing question (hatch4raceb16)
go to autozone and rent a timing gun. tell the guy you have never used it before and need the instructions with it.
it should spell it all out for you.
Old Dec 27, 2003 | 08:39 PM
Default Re: timing question (shakes)
um no, cam timing and ignition timing are different
Old Dec 27, 2003 | 09:27 PM
Shakes's Avatar
space cadet
well then take the damn timing belt off, reset the cam gears to zero. get a new belt and install.
Old Dec 28, 2003 | 06:09 AM
ok, u r bein an ***, im asking for help her not criticism. I know i have to take the timing cover off but im asking how can i tell if it skipped a tooth. In other words, what are the arrows on the cams supposed to point to??? dam...
Old Dec 28, 2003 | 06:21 AM
ziggity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch4raceb16 &raquo;</TD></TR><TR><TD CLASS="quote">My friend has a newer lude, a 99 SH ....His car is an automatic if that makes a diff.</TD></TR></TABLE>
not that it matters buy your friend doesnt have an SH if it is auto
Old Dec 28, 2003 | 07:47 AM
jc836's Avatar
First there are NO Prelude SH model cars that came stock with the SS gearbox to the USA. Second you need to take the cam covers off to check the position. There are marks in there. Make sure you are at TDC on #1 cylinder and follow the info in the Helm. The timing marks on the flywheel are under a rectangular rubber cover on the passenger side of the block. Hope this helps.
Old Dec 28, 2003 | 09:35 AM
Mikey3000's Avatar
if its automatic, the timing mark will be on the crank pulley. there's no flywheel. so line your TDC mark up first (on pulley with pointer on block). make sure that's #1 TDC by taking distributor cover off and seeing if the rotor is pointing to the #1 spark plug. then do whatever you have to do to expose your cam gears. the arrows on the gears should be pointing straight up and the dashes on the gears should be level with the top surface of the head (straight across).
EX-T
Jan 27, 2009 09:22 AM
BoostedH
Dec 9, 2008 10:34 PM
luvs2spooge
May 18, 2007 05:42 PM
sslude
Jun 25, 2004 07:53 AM
speedaccordinly24
Apr 21, 2003 08:10 AM
