Intercooler Question
Old Feb 20, 2004 | 06:38 PM
JDMH22's Avatar
Default Intercooler Question
I have a 92 Prelude with a JDM H22 and which is the best intercooler to use with out cutting to much to fit?
Modified by JDMH22 at 11:27 PM 2/20/2004
Old Feb 20, 2004 | 11:33 PM
Hawkze_2.3's Avatar
Default Re: Intercooler Question (JDMH22)
Are you putting a turbo on it???
Old Feb 21, 2004 | 12:28 AM
JDMH22's Avatar
Default Re: Intercooler Question (Hawkze_56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_56 &raquo;</TD></TR><TR><TD CLASS="quote">Are you putting a turbo on it???</TD></TR></TABLE>
Yeah I am putting a turbo in?
Old Feb 21, 2004 | 02:03 AM
Hawkze_2.3's Avatar
Are you getting a kit or just piecing one together??
Old Feb 21, 2004 | 07:49 AM
JDMH22's Avatar
Default Re: (Hawkze_56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_56 &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting a kit or just piecing one together??</TD></TR></TABLE>
Piecing it together
Old Feb 21, 2004 | 08:08 AM
Shakes's Avatar
space cadet
Default Re: (JDMH22)
in my experience you will have to cut to fit on any of them. to get it just right.
plus if you let size be your determining factor then you will most likely not the get most compatable IC for your application.
Old Feb 21, 2004 | 08:49 AM
JDMH22's Avatar
Default Re: (shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">in my experience you will have to cut to fit on any of them. to get it just right.
plus if you let size be your determining factor then you will most likely not the get most compatable IC for your application.</TD></TR></TABLE>
Thanks for the info, I knew that I would have to cut to make it fit right I just wanted one that I wouldnt have to cut a lot.
Old Feb 21, 2004 | 01:46 PM
SKDRCR's Avatar
the bigger the ic, usually the better. so i would hack away at the bumper
so you can get the biggest one possibile in there
xkrntamax
Jan 28, 2007 04:06 PM
mpxs20
Nov 4, 2005 05:22 AM
turbochargeb18c
Oct 12, 2005 12:58 PM
98cwitr
Jul 21, 2004 03:36 PM
I Like Boost
Mar 24, 2004 10:50 AM
