smokin vtec
Old Feb 17, 2004 | 03:17 PM
ludedude95's Avatar
Default smokin vtec
how much smoke comes out when u hit vtec ....how much is normal
Old Feb 17, 2004 | 03:21 PM
thehondaguru's Avatar
Very little and hardley notisable is about normal. If you can see it in your rear veiw when shifting its bad!!!
Old Feb 17, 2004 | 03:28 PM
ludedude95's Avatar
Default Re: (95 lude)
bad ??? i see alot of cars blow some black smoke when hittin it
i think some is kinda normal , and if its alot what does that mean ?
Old Feb 17, 2004 | 03:35 PM
yellow_jacket's Avatar
Default Re: (ludedude95)
It depends on the color of the smoke.
Black smoke=motor is running rich. Some under full throttle is normal though.
White smoke= water. Some vapor is normal when it is cold out or the car is cold, it is bad though if it smells sweet and overheating generall ensues.
Blue smoke=oil. You don't want to see this at all. If you are getting blue under load it is usually a sign of worn rings.
Old Feb 17, 2004 | 03:40 PM
99spanishGT
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedude95 &raquo;</TD></TR><TR><TD CLASS="quote">bad ??? i see alot of cars blow some black smoke when hittin it
i think some is kinda normal , and if its alot what does that mean ?</TD></TR></TABLE> dp they race alot of diesels in your area??
Old Feb 17, 2004 | 06:19 PM
ludedude95's Avatar
Default Re: (spanishlude)
save some $$$ and move on
yellow jacket thanx for the info ...
Old Feb 17, 2004 | 06:25 PM
ludeconduct8's Avatar
Default Re: (yellow_jacket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow_jacket &raquo;</TD></TR><TR><TD CLASS="quote">It depends on the color of the smoke.
Blue smoke=oil. You don't want to see this at all. If you are getting blue under load it is usually a sign of worn rings.</TD></TR></TABLE>
white smoke can also mean blown head gasket
Old Feb 17, 2004 | 06:28 PM
Matgallis's Avatar
Default Re: (ludeconduct8)
or just hot exhaust gases...
Old Feb 17, 2004 | 10:59 PM
makavelli1227's Avatar
if it is hot outside, and u arent suppose to see white smoke and u do, then u may have a blon headgasket..i think a little blue smoke comes out too..if i am correct.
Old Feb 18, 2004 | 08:10 AM
93ludeSi's Avatar
Default Re: (makavelli1227)
a lot of white smoke, is usually a sign of coolant in the combustion chamber, aka a bad headgasket. Black smoke is usually a sign of a rich fuel mix, and blue smoke is oil. all vtec motor blow a little oil, not much and usually not that visable. pull the spark plugs, they can tell you whats going on, wether it be coolant, oil, or fuel
Old Feb 18, 2004 | 09:41 AM
PirateMcFred's Avatar
Default Re: smokin vtec (ludedude95)
On all stock p13 preludes the A/F ratio richens the higher the RPM. So when WOT there will be an increasing amount of black smoke visible, especually if you have a testpipe instead of a cat. blue smoke = bad, white smoke when warm = bad. But you can check your plugs to see what kind of lean/rich condidtions the engine is running.
the Pirate
Old Feb 18, 2004 | 10:08 AM
Default Re: (93ludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">a lot of white smoke, is usually a sign of coolant in the combustion chamber, aka a bad headgasket. Black smoke is usually a sign of a rich fuel mix, and blue smoke is oil. all vtec motor blow a little oil, not much and usually not that visable. pull the spark plugs, they can tell you whats going on, wether it be coolant, oil, or fuel</TD></TR></TABLE>
Exactlly what I said and ment
Seraph
Nov 11, 2006 05:27 AM
john d ftw
Oct 9, 2006 11:36 AM
danny_305
May 11, 2005 03:45 AM
99shRIGGS
Dec 29, 2004 08:49 PM
BlckSI
21
Aug 12, 2003 06:46 AM
