Ground Wire Kit
Old Feb 18, 2004 | 05:00 PM
sk8erdude1386's Avatar
Default Ground Wire Kit
I was wondering if the ground wire kit for a 94 prelude would really make a noticeable difference??? Or is it just a waste of money. There is a kiy on EBAY for only $15.
Sean
Old Feb 18, 2004 | 05:16 PM
Behan's Avatar
Default Re: Ground Wire Kit (sk8erdude1386)
there may be some small gains on an older vehicle (like yours) but its easier to either [A.] clean your stock grounding points or [B.] make your own kit kit. if you search "grounding kits" in all forums you'll find plenty of DIY's on how to make it.
i recently "cleaned" my grounding points with some sandpaper and it only took about 20 mins and maybe .10 cents for the sandpaper. just unbolt the grounding points, sand the connector and surface it mates too.
Old Feb 18, 2004 | 05:24 PM
Default Re: Ground Wire Kit (Behan)
Ya I knew if you cleaned them they would work better just wondering if the kit was worth buying. I will search for ground wire kits. THANKS
Sean
vilaskhare
Audio / Security / Video
Aug 27, 2018 05:56 AM
AZNBIGPIMPN505
11
Dec 3, 2004 12:10 AM
accordsleeper02
Nov 4, 2004 02:03 PM
lmiguelvv
Jul 30, 2004 12:18 PM
joeski
Apr 10, 2003 12:58 PM
