Smaller wheels affect ATTS?
Old Oct 23, 2004 | 11:08 AM
lewdude's Avatar
Default Smaller wheels affect ATTS?
I cannot seem to get a solid answer from any mechanic or dealer that I speak with.
I have a 97 Honda Prelude SH and as you all know, it has the ATTS system. I want to get some 15 steelies for the winter but I was told by some dealers and mechanics that it will not work as the ATTS system will not work properly. I was thinking, why not get 15 inch steelies with tires that match the overall diameter of the original wheel and tire that I have on, which by the way are stock. What do you all think? Any suggestions would help.
Old Oct 23, 2004 | 11:37 AM
98 blacksh's Avatar
Default Re: Smaller wheels affect ATTS? (lewdude)
you should be ok as long as the outside diameter is the same size
Old Oct 23, 2004 | 11:45 AM
lewdude's Avatar
Default Re: Smaller wheels affect ATTS? (98 blacksh)
That's what im thinking. There shouldn't be anything wrong with having smaller wheels and taller tires to match the original wheel and tire size. I don't think that that application should mess with the ATTS. Im just wondering why Honda and some other mechanics think differently?
Old Oct 23, 2004 | 01:42 PM
Gerhard_001's Avatar
You can get 15 in for your car and run snow tires. IT does not trip the ATTS light or affect it if you have 15 in wheels (all the same series sidewall) on all four. If you just put them on the front and vice versa or have just one 15 in on with the factory 16's then ATTS with sense that and not function properly.
Old Oct 23, 2004 | 04:18 PM
DR's Avatar
DR
I ran 225/50/15 tires on my Type SH with no ATTS problems. These were about a 1/2" shorter in diameter than stock. After that I ran 225/50/16 tires which are about a 1/2 taller than stock with no probems either so as all your tires are the same diameter then you should be okay.
Old Oct 24, 2004 | 07:15 AM
LowFlyin''s Avatar
Default Re: Smaller wheels affect ATTS? (DR)
Same here, I run 245/45/16s on my '01 SH for track tires, and it has never tripped on me either.
Old Oct 24, 2004 | 02:46 PM
lewdude's Avatar
Default Re: Smaller wheels affect ATTS? (LowFlyin')
cool guys.
Thanks for all your help.
I guess you just cannot believe everything you hear from your Honda dealer.
SLO_EH2
Mar 21, 2009 08:54 AM
c1v1c98
Nov 8, 2008 01:25 PM
bist200
Jul 11, 2007 06:09 PM
zyntax
Jul 22, 2003 11:16 AM
Hapa88
26
Mar 30, 2003 02:03 PM
