E-Brake Light Problem
Old Oct 23, 2004 | 07:14 PM
Stationwagon's Avatar
Default E-Brake Light Problem
on my 5th gen, when i gas it in first and second gear, the e-brake light momentarily turns on. what could be the cause of this? is it causing damage to the car or no?
Old Oct 23, 2004 | 07:59 PM
MNsnowdaboy's Avatar
Default Re: E-Brake Light Problem (Stationwagon)
I know exactly what your problems is bro........if your e-brake still works that is.
Well first off fill check both your brake fluids and clutch fluid.....if they are low,even by a hair then your brake lights will come on. I suggest filling it up to the max, start your engine, and walla light should be gone.
I had this problem for about a month, finally got off my *** and fixed it.
Well hope this helps you, if not, drop another post and I'll see if I can give you another hint.
Old Oct 23, 2004 | 08:07 PM
yeah my e-brake still works, the light just comes on when i gas it, but yeah thanks man, i'll definately check it out, and if its still giving me problems, i'll let you know
Old Oct 23, 2004 | 08:15 PM
DR's Avatar
DR
Hold the e-brake down and see if it still happens. Sometimes the e-brake will get a little slack and will come up just enough to touch the switch which turns on the dash brake light.
Old Oct 23, 2004 | 10:43 PM
yeah i've tried holding the e-brake down and hitting the gas, the light still comes on.
i call it my bootleg shift light
Old Oct 23, 2004 | 10:54 PM
v4lu3s's Avatar
RTFM
you are low on brake fluid.
EFz6er
Aug 6, 2008 09:11 PM
JDMmovement
Apr 26, 2008 08:50 PM
gsr_pimp88
Nov 16, 2006 06:28 PM
m.c.
May 2, 2006 08:59 AM
ponzarelli
Dec 30, 2002 10:42 PM
