Coolant system
Old Oct 23, 2004 | 01:25 AM
vtec92lude's Avatar
Default Coolant system
I am just wondering exactly what is the proper procedure for getting air out of the cooling system (or how to bleed the sytem)?
This could be a good one for FAQ. As it is something everyone should know how to do.
Thanks for your help everyone
Old Oct 23, 2004 | 09:30 AM
vtec92lude's Avatar
Default Re: Coolant system (vtec92lude)
Doesn't anyone know how to get air out of the cooling system?
Old Oct 23, 2004 | 10:02 AM
fastprelude60657's Avatar
warm up the car to about 120 or so and shut it off then just loosen the bleeder screw till it stops air bubbels to solid coolant !!!its easy
Old Oct 23, 2004 | 12:45 PM
red92si's Avatar
Per the Helms manual just leave the radiator cap off and start the car, and let it reach operating temperature.
Or you can use the bleeder valve, but its the harder of the two ways.
Old Oct 23, 2004 | 03:05 PM
Nikoli's Avatar
Default Re: (red92si)
let it run with the cap off
Old Oct 23, 2004 | 03:10 PM
98TypeSH's Avatar
Default Re: (Deckedlude)
pull the cap off, put the heater on FULL BLAST, and let it idle till u see no more bubbles
Old Nov 3, 2004 | 07:47 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red92si &raquo;</TD></TR><TR><TD CLASS="quote">Or you can use the bleeder valve, but its the harder of the two ways.</TD></TR></TABLE>
How hard is it to turn the screw until you see green (or the new blue)? This is the most thorough way. Do it right.
Old Nov 3, 2004 | 08:21 AM
JT's Avatar
JT
If you really want to do it right, then get one these...
http://www.thetoolwarehouse.ne....html
Old Nov 3, 2004 | 11:11 AM
mgags7's Avatar
that filler/vac test thing is nice, but i think bleeding with cap off, then bleeding with the bleeder will cover it....dont forget to have the heater core all the way open though.....whats this talk of blue antifreeze....sounds bling....
Old Nov 3, 2004 | 03:52 PM
SuperSlow's Avatar
Default Re: (mgags7)
New Honda Radi Fluid is BLOOO.
jdm_obsession88
12
Sep 12, 2010 01:19 PM
Tunerguy1989
Jun 15, 2010 12:16 PM
tmurda253
13
Nov 4, 2008 08:53 PM
twenty
Jul 15, 2005 12:47 PM
1.8T_EG
Oct 28, 2002 04:17 PM
