starting engine
what is considered a "long start up" when starting the engine...
im scared that i might have bad compression.. because in the mornings (when its pretty cold) it takes like 2 seconds to start up... but when its warm it starts up hella fast..
is that normal? or is something wrong..
I usually turn the key forward to the acc position, wait
for the guages to turn off and then crank it.
This gives the fuel pump a chance to prime.
Then start it.
Try that and see if it starts up any faster
Then start it.
the battery will always put out less current when it's cold out. get a high cranking amp battery if you're really that concerned about the cold start cranking time.
Do you park on a hill or drive around between E or a 1/4 tank? I have noticed this with my Accord...I park on like a 5 degree grade, and have noticed this affects cold starting...Also, low fuel will cause this as well...Like SKDRCR said, turn it to ACC and let the fuel pump prime...
osbunjosh
12
Mar 3, 2013 12:20 PM
Narao
14
Oct 7, 2011 07:25 AM
jasongallagher
May 27, 2002 01:36 PM
