trany fluid
Old Oct 19, 2004 | 05:25 PM
copmagnet's Avatar
Default trany fluid
hey guys i need to put trany fluid in my trans where do i put it in at?
thanx in advance
Old Oct 19, 2004 | 05:28 PM
Hawkze_2.3's Avatar
Default Re: trany fluid (copmagnet)
Take off the passenger side wheel and look up and to the left (not far)from where the axle goes into the tranny. There is a drain plug that looks just like the engine oil drain plug. Have the car totally level and remove this bolt.
Then run a hose down from the top and put it in this hole. Fill it as full as you can without it draining out of the hole while the car is level and the bolt removed. What I mean by that is that it's filled to the right level when the oil is level with the opening...
Old Oct 19, 2004 | 05:54 PM
copmagnet's Avatar
Default Re: trany fluid (Hawkze_2.3)
thanx alot that help i got it in
frossteedhehe
Transmission & Drivetrain
Feb 14, 2013 01:07 PM
niceprelude
10
Feb 8, 2009 04:20 PM
Slow89HB
Oct 9, 2004 04:48 AM
4doorLX
Oct 2, 2002 10:55 AM
Ignitecivic
Apr 3, 2002 01:13 PM
