new brake problem....
Old Oct 23, 2004 | 10:54 PM
flip1199's Avatar
Default new brake problem....
ok i got some new brembo rotors and axxis/pbr ultimate pads but they wont fit. the new rotors measure 23mm and each pad measures 18mm. the pads and rotor measure about 59-60mm. the opening from the caliper body to the boot is 49mm. did i just get sent the wrong parts or am i forgetting some special little trick?
Old Oct 24, 2004 | 05:02 AM
britishlude's Avatar
Default Re: new brake problem.... (flip1199)
Have you pushed the pistons back into the calipers to make room for the new thicker pads ? Here is a step by step link with pics to change your rotors and pads, print it off and have it by you when you do the replacement.
http://www.ntpog.org/mods/four...shtml
Old Oct 24, 2004 | 06:12 AM
T-Mo's Avatar
I had that issue with Brembro rotors, but it ended up being that they gave me the ones for the V tec model and they were bigger than what mines was suppose to be.
Edit: I just re-read your post, it sounds like you didn't push thee piston back.
My problem was that the diameter of the rotor was bigger and I couldn't fit the caliper back on it.
Bad Brian
Suspension & Brakes
Sep 19, 2008 08:04 AM
triple
May 20, 2006 06:07 PM
hott-nix
Apr 4, 2005 01:33 PM
reeder321
18
Aug 10, 2004 08:17 PM
