LSD swapping
Old Oct 23, 2004 | 03:08 AM
vtec92lude's Avatar
Default LSD swapping
Is it possible to remove a JDM OEM LSD from an auto tranny and put it into a manual tranny?
Both trannies are H22- the auto w/LSD is JDM while the manual is US and w/out and in need.
And when I say IS it possible I know anything is possible, but I mean easy and logical?
Thanks for the help
Old Oct 23, 2004 | 09:28 AM
vtec92lude's Avatar
Default Re: LSD swapping (vtec92lude)
BUMP _-=-_-=-_
Anyone have any idea?
This may be a dumb question but I am curious.
Thank you
Old Oct 23, 2004 | 12:24 PM
v4lu3s's Avatar
RTFM
the JDM OEM LSD will not fir in a US tranny casing i know that for sure. the m2b4 has a larger differential casing...
Old Oct 23, 2004 | 03:14 PM
vtec92lude's Avatar
Default Re: (v4lu3s)
What about the m2b4 is the LSD from an auto able to go into it?
Old Oct 23, 2004 | 11:28 PM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">the JDM OEM LSD will not fir in a US tranny casing i know that for sure. the m2b4 has a larger differential casing...</TD></TR></TABLE>
that didnt answer anything...
it would make a lot of sense if it did, why would honda build two diff lsd's for the same gen tranny's, quaife works for a m2a4 as well as auto lude tranny right??? so i would think it would make sense for honda to use the same diff, are 4th gen man/auto axles the same???
Old Oct 23, 2004 | 11:47 PM
v4lu3s's Avatar
RTFM
well yes actually it DID answer the fact tht a JDM LSD will not fit a USDM case. and that is one PART of the quastion he asked.
Old Oct 24, 2004 | 11:43 AM
Pat McGroin's Avatar
Default Re: (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">
it would make a lot of sense if it did, why would honda build two diff lsd's for the same gen tranny's, quaife works for a m2a4 as well as auto lude tranny right??? so i would think it would make sense for honda to use the same diff, are 4th gen man/auto axles the same??? </TD></TR></TABLE>
Well sir, the m2b4 is the bastard child of the H trannies. Quaifes do not fit it, even PM satan_srv for proof.
Old Oct 24, 2004 | 02:02 PM
Default Re: (Pat McGroin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">well yes actually it DID answer the fact tht a JDM LSD will not fit a USDM case. and that is one PART of the quastion he asked. </TD></TR></TABLE>
my bad, i thought he was saying ALL were jdm tranny's, didnt see the US part
enzoferrari
Jun 5, 2016 05:18 AM
manchildteggy
Transmission & Drivetrain
May 1, 2012 10:54 PM
200 HP
Feb 20, 2012 11:24 AM
JDMKid71
Nov 18, 2005 02:39 PM
teg92
Oct 17, 2003 06:03 AM
