bad dizzy?
Old Jan 20, 2007 | 09:10 AM
3.point.2's Avatar
Default bad dizzy?
my car isnt getting spark and ive tested everything i can think of but the dizzy. how can i test it to see if thats the problem?
the weird thing is that the car will start and run for about 30 seconds if the cars been sitting for a couple weeks. ive changed the ignition coil, main relay, checked the plugs and wires. i havent checked for any shorts in the wiring but since it starts sometimes i assumed there probably isnt a short anywhere.
Old Jan 20, 2007 | 09:20 AM
Hawkze_2.3's Avatar
Default Re: bad dizzy? (h23eg)
Could be the ignitor inside the distributor...
Old Jan 20, 2007 | 09:25 AM
3.point.2's Avatar
Default Re: bad dizzy? (Hawkze_2.3)
how can i test the ignitor?
Old Jan 20, 2007 | 09:36 AM
xTravBx's Avatar
Sometimes I get bad dizzy when I stand up too quick.
Using the word "distributor" makes the search function a lot easier for people with similar problems.
Its not a "dizzy."
Old Jan 20, 2007 | 10:10 AM
Hawkze_2.3's Avatar
It's a long list of steps to test...do you have a manual?
If you have a manual you can test the ignition output signal. Do you have any CELs?
Old Jan 20, 2007 | 05:15 PM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">It's a long list of steps to test...do you have a manual?
If you have a manual you can test the ignition output signal. Do you have any CELs?</TD></TR></TABLE>
i have a helms but i forgot it at my apartment at school. i have a helms for a civic would the steps be the same? my olny CEL is for an O2 sensor
Old Jan 20, 2007 | 06:14 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23eg &raquo;</TD></TR><TR><TD CLASS="quote">
i have a helms for a civic would the steps be the same? </TD></TR></TABLE>
Give it a shot You might find out what's happenning....
Old Jan 21, 2007 | 08:12 AM
3.point.2's Avatar
just replaced the ignitor. cars been running for about 15 minutes now thanks for the help
Old Jan 21, 2007 | 10:58 AM
Hawkze_2.3's Avatar
Default Re: (h23eg)
:borat: Very niiice :borat:
oakpwr
17
Jan 29, 2024 10:14 AM
redlinexd
Dec 1, 2007 12:33 PM
InvaderTrax
Oct 15, 2006 05:59 PM
ActiveAero
Sep 16, 2006 11:21 AM
tgreaves
Sep 1, 2005 06:10 AM
