Prelude ?
Old Jan 21, 2007 | 02:31 PM
sileighty_911's Avatar
Default Prelude ?
Um, I have a 92 Prelude with a JDM F22B I just bought. What does it mean by the ps rack is leaking and how do I resolve it?
Old Jan 21, 2007 | 04:17 PM
manbearpig's Avatar
Default Re: Prelude ? (sileighty_911)
https://honda-tech.com/zerothread?id=1517004
Old Jan 21, 2007 | 05:34 PM
Silver Surfer's Avatar
Default Re: Prelude ? (joinerneal)
your seals on your powersteering rack have most likely gone bad and need to be replaced.......hopefully nothing is bent or warped causing the leak
Old Jan 21, 2007 | 06:27 PM
tmrtwo's Avatar
I had the same problem wit my lude when i bought it. Was cruising down the road wit a bunch of friends, all of a sudden the car wanted to pull to the left. Also on turns the wheel would jerk. What i did was found the cheapest rack and pinion online. Printed up the sheet with the price on it and went to advanced autoparts. They matched the price and i saved like 200 dollars. Only took like 6 hours to put in. Just make sure u heat the lines up when u remove them u DONT want them to break it will up the cost alot and make alot tougher. Also when u put the power steering fluid in after install make sure u use hondas ps fluid.....thats the only kind u can use for the lude. Also u will need a alignment when done. Also make sure u mark the tie rod ends so u can get ur alignment as close as possible so u can drive it to get the alignment w/o eating tires. Cost with labor was like 800-1000 to do at a garage. Cost me like 350 with everything to do by myself. Hope this helps and good luck with it.
Old Jan 23, 2007 | 08:12 PM
Default Re: Prelude ? (tmrtwo)
Since I'll probably have to replace the rack anyways, do u think the complete ones on eBay are any good? All the ones I looked at were complete and stock and in good or excellent condition.
vladimir_GT
Nov 9, 2012 07:34 AM
extremebtf
Apr 3, 2011 06:05 PM
rogall
Jan 4, 2005 10:27 AM
NZ Vtec Weapon
Feb 7, 2003 04:46 PM
The Punisher
May 30, 2002 02:25 AM
