window problems
Old Jan 17, 2007 | 06:42 AM
Serenity Now!'s Avatar
Default window problems
on my 4th gen lude, i pulled down my window all the way (drivers side) and then i heard a rreally wierd "grinding" noise coming from out of the door...i paniced and turned the car off. then, when i turned the car on again, the window no longer pulls up no matter how many times i push the button for it to go up...any tips aas to what is going on would be appreciated.
Old Jan 17, 2007 | 08:36 AM
'95 BA8's Avatar
Default Re: window problems (thecanyon2k4)
Does it make any noise? Does it sound like it's trying to go up? Take the inside of the door out and check that everything is in place.
Does the passenger window work?
Oh when when taking the inside of the door out, be carful not to break the powerlock, window switch "holder" the long plastic part.
Old Jan 17, 2007 | 04:13 PM
Default Re: window problems ('95 BA8)
no, it makes no noise at all, as if it isnt working anymore....and the passanger's side IS working
Old Jan 18, 2007 | 02:32 AM
'95 BA8's Avatar
Then take out the inside of the door and check that everything is in place, and nothing came off
Old Jan 18, 2007 | 04:06 AM
prelude4ever's Avatar
Ok man forget all the bull **** that they r talking about you have problem with the window motor inside gear its made of plastic i hade the same problem now you have to take out the motor from inside using alan key then you have to open the motor and take out the white plastic gear now you have tow option. either find the same gear or make new one at machine shop .
Old Jan 18, 2007 | 07:06 AM
professorman's Avatar
Default Re: window problems (prelude4ever)
I have a window motor for sale. My window tabs had broke off the lifter and had messed up, so I changed everything and got a new motor. Let me know.
Old Jan 18, 2007 | 07:30 AM
staticrex's Avatar
Default Re: window problems (profroopchan)
When I had my 4th gen I had the same problem, replaced the motor still didn't work. Ended up being the switch on the door. try replacing that first its easier and cheaper.
00zzySi
Sep 28, 2010 09:43 PM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
26
Nov 10, 2008 06:41 AM
Lb1atx
Aug 29, 2007 08:14 AM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
NuclearB18B
Jun 6, 2002 11:11 PM
