timing problems
Old Jan 21, 2007 | 12:57 PM
accord-h22's Avatar
Default NEED HELP!! timing problems
need help timing belt jumping teeth on cams when turned i have a 13:1 compression all motor h22 completely built
Modified by accord-h22 at 2:34 PM 1/21/2007
Old Jan 21, 2007 | 08:51 PM
ge_itr's Avatar
Default Re: NEED HELP!! timing problems (accord-h22)
this is not related to the timing belt but what gas are you using for that compression? is it street? how's it running? i'm planning to run all motor street but kinda scare to go that high. i'm thinking 12.0:1.
Old Jan 22, 2007 | 03:42 AM
Revi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-h22 &raquo;</TD></TR><TR><TD CLASS="quote">need help timing belt jumping teeth on cams when turned i have a 13:1 compression all motor h22 completely built
Modified by accord-h22 at 2:34 PM 1/21/2007</TD></TR></TABLE>
So what exactly do you want to know? Ok, you jumped teeth, now what? Did you bend valves? Dont know how to put it in timing? Give us more info.
Old Jan 22, 2007 | 11:46 AM
accord-h22's Avatar
Default Re: NEED HELP!! timing problems (Revi)
newly built motor has not been started yet putting timing belt on and then turning the gears and it jumps teeth the motor is out of the car
i am goning to have to run 93 octan or more to run this motor
Old Jan 22, 2007 | 11:55 AM
nonvteclude's Avatar
ok so do you not know how to time it and your asking us how to? im not really understanding what your asking all together.
Old Jan 22, 2007 | 12:07 PM
accord-h22's Avatar
Default Re: NEED HELP!! timing problems (nonvteclude)
pretty sure i am putting it in timing right i may be wrong what is the right way?
when i had the timing belt in and in timing for what i think i gave it a turn and it jumped a tooth
do you think it is auto tenisor if so i am going to be converted to a manual
Old Jan 22, 2007 | 04:29 PM
spun311's Avatar
Yea, it sounds to me like your timing belt might not be tight enough and is therefore jumping teeth. I would strongly suggest converting to a manual tensionor set up. Its cheap insurance.
Old Jan 22, 2007 | 06:18 PM
ge_itr's Avatar
let me know when you get it running. i'm might start my project sometime this month, next month by the latest. i might be going through this whole mess too. i'm not even sure how to do the timing. just going by the book and hope it helps.
MyWhiteEJ6
12
Nov 10, 2013 06:38 PM
wu tang
Jun 28, 2007 08:26 PM
MISFITofMAGIC
Jan 7, 2006 08:53 PM
eatbieodie2
Apr 28, 2005 12:18 AM
mister2racer
Mar 15, 2004 12:34 PM
