block damage/rebuild
Old Jan 16, 2007 | 09:21 PM
ge_itr's Avatar
Default block damage/rebuild
this is h22a1 block. one of the rod broke and did the damage. i want to know if i could still sleeve and rebuild it.
Old Jan 16, 2007 | 09:48 PM
importfanatic17's Avatar
Default Re: block damage/rebuild (ge_itr)
I have no idea, but WOW!
Old Jan 16, 2007 | 09:49 PM
thegeorge613's Avatar
Oh snap! That's some crazy damage! How the heck did you break a rod?
Old Jan 16, 2007 | 09:54 PM
ge_itr's Avatar
Default Re: block damage/rebuild (thegeorge613)
testing out the car on the highway.
Old Jan 17, 2007 | 03:49 AM
flyrod's Avatar
I think that block can be repaired by sleeving. Inspect the block carefully for cracks. Good luck.
Old Jan 17, 2007 | 04:52 AM
Iboot's Avatar
Default Re: block damage/rebuild (flyrod)
daamnn....just put it back together , sell it to some retard. then buy yourself a k20.
Old Jan 17, 2007 | 05:17 AM
117's Avatar
117
The oil squirter of obviously toast. Sleeves will repair the cylinder walls, but won't repair that damage to the very bottom side of the block. You could probably smooth that out with a cartidge roll fairly easily.
First thing I'd do is take the block to a machine shop to have it hot tanked and inspected for cracks.
Old Jan 17, 2007 | 05:49 AM
alterdcreations's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">testing out the car on the highway.</TD></TR></TABLE>
it always good to test things out
what rpms were you spinning?
Old Jan 17, 2007 | 06:17 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iboot &raquo;</TD></TR><TR><TD CLASS="quote">daamnn....just put it back together , sell it to some retard. then buy yourself a k20.</TD></TR></TABLE>
good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">The oil squirter of obviously toast. Sleeves will repair the cylinder walls, but won't repair that damage to the very bottom side of the block. You could probably smooth that out with a cartidge roll fairly easily.
First thing I'd do is take the block to a machine shop to have it hot tanked and inspected for cracks.</TD></TR></TABLE>
Old Jan 17, 2007 | 06:55 AM
ge_itr's Avatar
Default Re: block damage/rebuild (Iboot)
not my kind of style.
ge_itr's Avatar
Default Re: block damage/rebuild (alterdcreations)
happened arounf 6000rpm.
Old Jan 17, 2007 | 07:07 AM
that sucks
is their any crank damange?
you are lucky the rod didnt go thru the side of the block
Old Jan 17, 2007 | 12:42 PM
jdmcivicferio's Avatar
mine was in worse shape then that, just make sure the mains are not scared. The water jacket on a h22 is pretty far away so you don't have to worry there.
Old Jan 17, 2007 | 01:14 PM
prelude1897's Avatar
Daaamn
Old Jan 17, 2007 | 02:39 PM
ge_itr's Avatar
the rod journal is all scratched up. cracked my water pump and broke the belt. broke the key way on one of my sprocket (across from water pump and oil pump). can anyone tell me what's for and where to get it? scratches and dents inside block.
Old Jan 17, 2007 | 04:22 PM
if you need another block, I have one that's been just sitting in my garage for awhile that I'll sell for cheap. Just let me know
Old Jan 17, 2007 | 04:59 PM
AndyD's Avatar
HAHAHAHAHAHAHA That made me laugh out loud, literally!!
What are your plans for the engine?
I guess your options are fairly open. You could go with an F22/F23 bottomend, H23 block, or an H22 block/shortblock.
If it was me, I would go with the H22 head on an F23 bottomend.
Old Jan 17, 2007 | 06:48 PM
ge_itr's Avatar
Default Re: block damage/rebuild (AndyD)
getting some sleeves, bore to 89mm. 12.0:1 compression ratio, light weight rods, light weight crankshaft with 95mm stroke. what do you guys think?
what do you guys think i should do to the oils squirters?
DA9tothewheel
Engine Machining & Assembly
Aug 21, 2016 02:48 AM
TomTread
Apr 21, 2008 01:35 PM
JDM00SI
Nov 1, 2005 10:53 AM
ieldib
Feb 21, 2005 06:57 AM
