find a ECU
Old Jan 18, 2007 | 05:34 AM
shahmiezan's Avatar
Default find a ECU
Hi all,
i m using 90 accord with F20A engine (japan). My ECU got problem right now. i can't start my engine because the Engine Check lamp indicator is always turn ON. I don't know what is actual problem, but my friends suggest me to change my ECU. I would like to know more abt ECU and how much to buy.
Old Jan 18, 2007 | 05:55 AM
BB2H22's Avatar
You can search and find the ECU but unless you have a bad ECU, that shouldn't be your problem.
Edit: The ECU factory, with that engine is a PT2.
Modified by BB2H22 at 7:06 AM 1/18/2007
Old Jan 18, 2007 | 09:02 AM
l2yanE's Avatar
sounds like you need to take it to a shop if your completely clueless at this point-
Old Jan 18, 2007 | 09:50 AM
kulrevon's Avatar
Default Re: (l2yanE)
well I will give you information but I don't know if you will understand it. You have to find the connecter. I believe its behind the center console or by the pasenger right side kick panel. Its a connector which consists of 2 wires which you have to connect together using a jumper.
by doing this your check engine light will flash out a series of codes. this can tell you why the light is on.
Old Jan 18, 2007 | 01:01 PM
preludefien
Guest
Posts: n/a
Default Re: (kulrevon)
yea check your codes...you very seldomly come across a bad ecu...well atleast in my eperience. but there is a blud clip under the driver side center console and just stick a paper clip in it and turn your car key to the second position and it will blink the cel codes you are throwing. if that wasnt clear then just search it.
Old Jan 18, 2007 | 01:11 PM
94Vtecluder's Avatar
Default Re: find a ECU (shahmiezan)
You would prob get more information if you post this in the ACCORD forum.
Old Jan 19, 2007 | 05:39 AM
shahmiezan's Avatar
hi, if i do that and see my check engine indicator is blinking, that mean my ECU didn't have problem right?...
how about if the indicator still ON?... where can i know what is actually problem...it is ECU or another Part.
gtownjoe
Jan 13, 2012 02:32 PM
bub113
Dec 22, 2008 04:26 PM
punkrocksamurai
Dec 9, 2008 08:34 PM
houdas
Jan 22, 2004 06:41 AM
CleanLIttleLude
Jun 13, 2003 12:09 PM
