Serious vibration problem
Old Jan 24, 2007 | 09:17 AM
prelude1897's Avatar
Default Serious vibration problem
I'm have a serious vibration problem with my car. Anytime I'm on the hwy, and I give it gas, something starts to vibrate at the front of my car. If I'm going about 80mph and gas it, it shakes real bad, but if I"m going about 60mph or so, it's not as bad. My wheels are balanced, my axles are tighten, and I still can't figure out what hte problem is. My steering wheel doesn't shake at high speeds or anything like that. I did a valve adjustment possibly thinking that's what it could be, but it wasn't, so can anyone help me out in this situation? This didn't start till 2 days ago when I was coming home from about a 4 hour drive.
Old Jan 24, 2007 | 09:22 AM
Hawkze_2.3's Avatar
Default Re: Serious vibration problem (prelude1897)
If it only vibrates on acceleration, I would bet it's axles. I have had that problem twice in the past and it was my axles....
Old Jan 24, 2007 | 09:33 AM
RA102725's Avatar
possibly a brake caliper hanging up? that can cause shake even when your foot isnt on the pedal
Old Jan 24, 2007 | 09:39 AM
Revi's Avatar
Default Re: Serious vibration problem (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">If it only vibrates on acceleration, I would bet it's axles. I have had that problem twice in the past and it was my axles....</TD></TR></TABLE>
I had vibration while accelerating at about 70-80, i rebuilt the inboard joint on my driverside driveshaft and problem has gone away.
Old Jan 24, 2007 | 10:31 AM
Default Re: Serious vibration problem (Revi)
A friend of mine also said it could possibly be the axles, so I'll get the driverside one rebuilt, cause the boot is torn, but it's been like that for about 1.5 years or so. Thanks for the input guys. I'll update everything if it gets fixed
Old Jan 24, 2007 | 10:55 AM
Revi's Avatar
If that boot has been torn for that long its very likely the bearings are trashed. Luckly for me when i did my swap the OEM inboard joints were still attached to the motor so i had some nice OEM bearings i used. The joint that went bad was a remanufactured with aftermarket bearings that were crap.
Old Jan 24, 2007 | 03:18 PM
*UPDATE*
Woot Woot!! Just finished changing the driverside axle out about 30min. ago and took it for a test drive adn the problem is gone..Thanks Revi and Hawkze_2.3
it was just the axle that needed to be replaced
Mods can lock this now
Old Jan 24, 2007 | 05:47 PM
GwenLover's Avatar
I had the same problem.. it turned out to be my crank sensor on an H22.. If not that it could be other sensors... Is your ride throwing a CEL???
Old Jan 24, 2007 | 06:55 PM
Default Re: Serious vibration problem (GwenLover)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GwenLover &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem.. it turned out to be my crank sensor on an H22.. If not that it could be other sensors... Is your ride throwing a CEL???</TD></TR></TABLE>
nope, no cels...It was just the axle needing to be replaced
Old Jan 25, 2007 | 02:56 PM
1GPlusSH's Avatar
Seems like it would do that at all speeds.
white_db8
Jun 17, 2007 08:01 AM
Joe...
Dec 31, 2006 12:26 PM
projectTeG
Sep 29, 2005 09:04 PM
msmithgsr2131
Jul 18, 2004 06:30 AM
j93lude
Jan 28, 2003 07:33 AM
