O2 sensor..will it work without cat
Old Jan 17, 2007 | 06:48 PM
k_lude's Avatar
Default O2 sensor..will it work without cat
if i was to make a straight pipe all the way from my header to the back would i know i somehow need to drill new holes for the o2 sensors and will it work properly since i have no cat? or do i have to do something else?
Old Jan 17, 2007 | 06:50 PM
Hawkze_2.3's Avatar
Default Re: O2 sensor..will it work without cat (k_lude)
What year is your car?
Old Jan 17, 2007 | 06:51 PM
k_lude's Avatar
Default Re: O2 sensor..will it work without cat (Hawkze_2.3)
5th gen 1998
Old Jan 17, 2007 | 06:54 PM
Hawkze_2.3's Avatar
So you're OBD2 and you have 2 sensors, one before and one after the cat. Yes, it will throw a code because of the 2nd sensor...
Old Jan 17, 2007 | 06:56 PM
k_lude's Avatar
yea...i was thinking it would..but how do i get rid of it without tuning or nothing still with the pipe...
Old Jan 17, 2007 | 07:06 PM
Hawkze_2.3's Avatar
OBD1 conversion, some kind of engine management that will let you bypass it, O2 simulator, etc...
Old Jan 17, 2007 | 07:08 PM
k_lude's Avatar
thanks for the help man...but how much do those simulators cost??and is there a site for them..
Old Jan 17, 2007 | 07:11 PM
Hawkze_2.3's Avatar
http://www.google.com
Old Jan 17, 2007 | 07:12 PM
k_lude's Avatar
thanks though..its a pain looking for parts like those though
Old Jan 18, 2007 | 03:12 PM
PrettyLude's Avatar
http://www.casperselectronics.com they have a pretty good plug and play one
Old Jan 18, 2007 | 03:33 PM
madcatz's Avatar
can you vouch for that one?
Ive heard about it and am still thinking that the 10k resistor trick is still the best work around....any input?
Old Jan 18, 2007 | 04:20 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the help man...but how much do those simulators cost??and is there a site for them..</TD></TR></TABLE>
I have the Ziptech O2 simulator. Works wonders. Had it on the car for over 2 years, no CEL ever! Cost me $50 back then. Probably find it for cheaper now.
It's an easy install if you're semi-skilled with a soldering iron.
Old Jan 18, 2007 | 04:21 PM
kulrevon's Avatar
Default Re: (madcatz)
you can also do the defouler trick. You take two sparker defoulers (non-foulers) sold at any auto parts stores. you drill the hole bigger on one so the o2 can fit through it moves it back from the exuahst like a spacer. and the second you leave how you bought it. SO you install them like O2 / drill nonfouler/ nonfouler/ test pipe.
Old Jan 18, 2007 | 04:26 PM
Finest's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">you can also do the defouler trick. You take two sparker defoulers (non-foulers) sold at any auto parts stores. you drill the hole bigger on one so the o2 can fit through it moves it back from the exuahst like a spacer. and the second you leave how you bought it. SO you install them like O2 / drill nonfouler/ nonfouler/ test pipe.</TD></TR></TABLE>
Sounds like alot of work. And is it even gauranteed to work?
Old Jan 18, 2007 | 04:47 PM
madcatz's Avatar
ive heard about it, but i have yet to see one in person or in pics from a respectable source...not saying anyone would pull the wool over our eyes, but i want confirmed working order before i go sending more money on this already empty the pocketbook project.
is ziptech still in business? i looked up the casper one and nowhere on their site (via their search function) is there a o2 simulator
Old Jan 22, 2007 | 12:34 PM
kulrevon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
The nonfoulers are $4 and all you have to do is drill. thats alot of work?
Maybe I made it sound more complicated then it is.
http://www.amazon.com/Help-420...otive
I will try to find the post. But plenty of people have done this and mad it work. Everyone with an evo/wrx uses this trick when they get rid of their cats.
https://honda-tech.com/zerothread?id=1841240
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">
Ive heard about it and am still thinking that the 10k resistor trick is still the best work around....any input? </TD></TR></TABLE>
The resister trick will fix the heater portion of the o2 sensor. Like it wont throw an o2 heater code. But it won't fix the actual o2 part.
I know you guys question alot of people. But I have done the research and seen it work.
Modified by kulrevon at 4:50 PM 1/22/2007
Old Jan 22, 2007 | 12:50 PM
E-Money's Avatar
Impossible to find O2 sims now, unless used.
I had my O2 sensor sitting on the exhaust system heatshield and the CEL would come on and off... was strange... still pluged into the harness
Old Jan 22, 2007 | 07:24 PM
madcatz's Avatar
kulrevon I understand what your saying, as i have done this research too, but i have seen both sides of the fence with each description: anti fouler, simulators, 10k resistors, work arounds.
Im going to be running a test pipe with the Greddy Emanage so i wont need the second O2 since it just checks to make sure the cat is doing its job. I will have a Innovate LM-01 wideband in place connected to the Brockway R920 and the Emanage for inputs
Old Jan 24, 2007 | 09:11 PM
Vertex Spirit's Avatar
yea if you run 2 o2 sensors in the same pipe without a cat, the signals will register the same and you will throw a code. i bought a simulator for my 2000 civic on ebay, was like $10, spliced it into the 2ndary o2, and ran turbo with a "high flow " cat and no CEL for 2 years now
go on ebay and search "o2 simulator"
Old Feb 14, 2007 | 07:17 PM
hndacord02's Avatar
Default Re: O2 sensor..will it work without cat (Vertex Spirit)
get a defouler, i have them forsale... it takes car of the CEL... pm me for details...
pompom
Sep 14, 2006 05:00 PM
wwang924
Feb 23, 2006 07:03 PM
hotboi850
Aug 18, 2003 08:46 PM
Mike95lude
Jan 16, 2002 09:19 AM
JinMTVT
Aug 11, 2001 08:01 PM
