clutch problem?
Old Apr 3, 2007 | 07:26 PM
mikeaitken's Avatar
Default clutch problem?
it seems like when i press my clutch pedal in it has no pressure in it it just drops in real easy.I can still shift somewhat but it seems a lil harder to put in gear and all i have to do is barely lift my leg to shift and i take off.Any help. thanks.
Old Apr 4, 2007 | 12:27 AM
jdmh22a1's Avatar
did u recently.changed ur clutch....bc when i changed my clutch...i had to bleed it....until there is no air..in the system....
Old Apr 4, 2007 | 09:21 AM
mikeaitken's Avatar
Default Re: (jdmh22a1)
Nah. i have a clutch and flywheel set to go to be changed but haven't had the time yet.I have fluid too.
Old Apr 4, 2007 | 02:58 PM
Flex'n Da Lude's Avatar
Default Re: (mikeaitken)
seems there is a leak in in one of the clutch cylinders. Any wetness near the pedal? I'd check their fluid first.
Old Apr 5, 2007 | 05:00 PM
mikeaitken's Avatar
Default Re: (Flex'n Da Lude)
yah its not wet near the pedal or anything. like it honestly just gave out overnight.i checked the fluids and its all good.i have a clutch and flywheel to go in, should i just wait and put that in and bleed it, and see how that goes or maybe replace my master cylinder and whatnot?
Old Apr 6, 2007 | 08:47 AM
rbyrdman1's Avatar
check the slave and see if u can adjust the push rod by the pedel just had the same prob i jus fixed mine
Old Apr 8, 2007 | 05:54 AM
mikeaitken's Avatar
Default Re: (rbyrdman1)
yah the seal on the cylinder went. thanks for all the help and guys.
Old Apr 21, 2007 | 07:06 PM
honda~help's Avatar
i'm having problems with my clutch i bled it, then the next day it's on the floor what can it be?
Old Apr 22, 2007 | 03:20 AM
mattsnooz's Avatar
Default Re: (honda~help)
the next day, whats on the floor? hydraulic fluid(dot 3/4 fluid)?
Old Apr 22, 2007 | 10:45 AM
honda~help's Avatar
Default Re: (mattsnooz)
the pedal
88aeFC3S
20
Apr 13, 2009 03:48 PM
CRexcellence
Oct 10, 2007 12:27 PM
Lb1atx
Sep 7, 2007 05:16 AM
a1320addict
Apr 17, 2005 09:20 PM
94dxt
May 8, 2003 06:25 PM
