Bolt threads on upper arm is screwed.. Can I replace it?
Old Mar 28, 2007 | 04:58 PM
GraphiteMW's Avatar
Default Bolt threads on upper arm is screwed.. Can I replace it?
On the upper-arm there is a pin you remove then you unscrew the 17mm nut well. The threading on the bolt is really messed up because I used the pitman puller and it slide off the edge and screwed up the threading horribly and now the nut won't screw back.. Is it replacable? or would I have to get a new upper arm?
Btw, are the rear upper arms on a 97-01 base the same as a 92-96.. I am looking at pics and they look the same. I found some on ebay only for 97-01 and none for 92-96 and i need some desperately!!!
Also does anyone know the the bolt size for it? I am gonna cop a re-threader to see if I can restore the threads a bit. My dad went to autozone and said it was M12 x 1.25 but I don't trust them
Modified by GraphiteMW at 6:31 PM 3/28/2007
Modified by GraphiteMW at 6:35 PM 3/28/2007
Modified by GraphiteMW at 6:56 PM 3/28/2007
Old Mar 29, 2007 | 05:44 AM
GraphiteMW's Avatar
damn nothing?
Old Mar 29, 2007 | 05:51 AM
SnlpeR's Avatar
run a tap or die thru it
could possibly save the threads
edit: i didnt see that you edited
but bring the castle nut bolt with you to autozone to find the threading
Old Mar 29, 2007 | 06:08 AM
prelude_h22vtec's Avatar
are you talking about the anchor bolts? or the through bolt that goes through the bushing?? i would just try to retap it. if not take the nut and bolt to autozone, and if that fails, go to a junkyard.
LutherX
Aug 21, 2011 07:59 AM
joshmak
11
Apr 21, 2010 11:52 AM
FuLlRaCe XLR8R
Suspension & Brakes
Feb 27, 2007 11:33 PM
danvuquoc
Suspension & Brakes
11
Jan 25, 2006 11:30 AM
