Distributor ?'s
Old Apr 3, 2007 | 08:30 AM
LukieLuc's Avatar
Default Distributor ?'s
okay hears the deal i tried replacing my distributer cap and rotor under the cap today for the first time, but when i removed the distributer cap, the rotor under the cap, screw was stripped so i cant take it out, i need help???? anyone know how i can remove it without hurting the distributer??? thanks
Old Apr 3, 2007 | 08:31 AM
Hawkze_2.3's Avatar
Default Re: Distributor ?'s (LukieLuc)
Rundown = stripped?
Old Apr 3, 2007 | 08:32 AM
LukieLuc's Avatar
Default Re: Distributor ?'s (Hawkze_2.3)
yea man, what should i do?
Old Apr 3, 2007 | 08:45 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">yea man, what should i do?</TD></TR></TABLE>
Dremel a slot in the screw as deep as you can without going too far, soak it in WD-40 or PB Blaster, then get a slotted bit and put it in a small 5/16 socket (or whatever size your bit is), and carefully undo it with a ratchet or breaker bar.
Old Apr 3, 2007 | 09:26 AM
LukieLuc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Dremel a slot in the screw as deep as you can without going too far, soak it in WD-40 or PB Blaster, then get a slotted bit and put it in a small 5/16 socket (or whatever size your bit is), and carefully undo it with a ratchet or breaker bar. </TD></TR></TABLE>
Im sorry but im a noob can you explain this further, "dremel"?? "Slotted bit"???? thanks
Old Apr 3, 2007 | 09:37 AM
LukieLuc's Avatar
Old Apr 3, 2007 | 09:38 AM
Hawkze_2.3's Avatar
Im sorry but im a noob can you explain this further, "dremel"?? "Slotted bit"???? thanks</TD></TR></TABLE>
Dremel (I assume you don't have one):
It's an electric rotary tool. You can cut a little slot in the screw with a cut-off wheel as shown in the pic.
Slotted bit:
Like the tip of a flathead screwdriver, but it's a little bit that you can put into a socket to get more torque on it.
Old Apr 3, 2007 | 09:39 AM
LukieLuc's Avatar
okay thanks man i understand 100% lol thanks for taking your time
Old Apr 3, 2007 | 09:43 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">okay thanks man i understand 100% lol thanks for taking your time</TD></TR></TABLE>
Old Apr 4, 2007 | 06:35 PM
AdReNaLiN's Avatar
I just did this - used lots of WD40 and hammered a screwdriver onto the screw to take it off.
REPLACE THE SCREW!
The_Ricky_Is
Sep 19, 2006 08:31 AM
jus2sho
Sep 8, 2006 09:30 AM
bleedblue94
Jan 5, 2006 06:40 AM
B18C5er
Nov 15, 2004 05:20 PM
spooncvc
May 17, 2004 11:26 PM
