Balljoint
Old Apr 1, 2007 | 03:56 PM
kornerk12's Avatar
Default Balljoint
I used the pickle fork type balljoint puller anyway i ended up tearing some boots. I see that i can buy a new boot from honda but how do you install just a boot and pack it with grease ?
Also if a balljoint spins while you try and tighten or loosen it does that mean it is bad ?
Old Apr 1, 2007 | 04:00 PM
Hawkze_2.3's Avatar
Default Re: Balljoint (kornerk12)
Yeah, just get as much grease as you can in there and then there should be a spring clip to hold the boot on.
If it spins, there's either grease in the taper-bored part or it's not pulled through far enough to catch.
Old Apr 1, 2007 | 04:09 PM
kornerk12's Avatar
Default Re: Balljoint (Hawkze_2.3)
where is the taper-bored part and what is may not be pulled through enough ? Sorry i am just not very familiar with the internals of a balljoint.
Old Apr 1, 2007 | 04:34 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">where is the taper-bored part and what is may not be pulled through enough ? Sorry i am just not very familiar with the internals of a balljoint. </TD></TR></TABLE>
The shiny metal part directly under the boot. That's the part that makes contact with the hub or knuckle or whatever the joint is attaching to:
The part that always gets stuck or rusted tight tht you have to use the ball joint puller for
nomoreavril
17
Dec 14, 2006 09:25 PM
reed857
18
Mar 15, 2006 08:19 PM
FOrSfEd
Jan 27, 2005 07:17 AM
Cuong-nutz
22
Nov 19, 2004 11:50 AM
kb798
13
May 27, 2004 12:55 PM
