rear alignment?
Old Apr 2, 2007 | 12:40 AM
90hbvtec's Avatar
Default rear alignment?
ok i have a 97 lude and wondering if we need to have our rear wheels align?..or is it usually only the front needs to be align?.after having me car lowered. les schwab has a Thrust alignment which is 50 bucks and the 4 wheels alignment for 75 bucks.. is the 4 wheels alignment needs?.. need info..Thanks
Old Apr 2, 2007 | 02:02 AM
john666's Avatar
Default Re: rear alignment? (90hbvtec)
imo i dont think you need to worry about your alignment as much as a camber problem depending of course how low you went. of course someone will jump in to add more info i bet
Old Apr 2, 2007 | 09:27 AM
avallach's Avatar
Yes, get a 4 wheel alignment. Zero out the toe.
Old Apr 2, 2007 | 05:11 PM
InvaderTrax's Avatar
2 wheel alignment is basically worthless, unless you recently did a 4 wheel, then altered only your front suspension. You align the front off the rear, so if your rear is out, aligning the front will most likely make everything worse
pKjai
Suspension & Brakes
Oct 27, 2010 08:28 PM
VTEC_Du_Ma_Mai
Suspension & Brakes
30
Dec 4, 2008 05:19 AM
Dylanamus
Suspension & Brakes
Apr 4, 2008 06:37 PM
jvcnyc
Apr 4, 2004 06:59 PM
