temperature sending unit
Old Apr 2, 2007 | 08:40 PM
Jason-K's Avatar
Default temperature sending unit
Ok call me retarted but i looked this up and I didnt find it.
I am looking for the temperature sending unit, the one that displays
the temp on the guage. In the manual it sais it is "by the thermostat housing"
and there are quite a bit of sensors next to the thermostat housing, so my
question is can anybody tell me where exactly the sending unit is?
There is one on the thermostat housing itself, two under the distributor (one is a
little tiny one) and one on the front of the head where the top radiator hose
connects to. Which one is the temperature sending unit, and which one is for the
radiator fan switch? It is a 92 lude h23 btw. Thanks alot!
Old Apr 2, 2007 | 08:48 PM
Hawkze_2.3's Avatar
Default Re: temperature sending unit (Jason-K)
The arrow is pointing to the sender for the temp gauge.
Old Apr 2, 2007 | 08:56 PM
Jason-K's Avatar
ok thanks alot! i really appreciate it, by any chance would you know which switch is the radiator fan switch?
Old Apr 2, 2007 | 09:05 PM
Jason-K's Avatar
bump i need to know where the radiator fan switch is!!! plz help!
Old Apr 2, 2007 | 09:13 PM
Hawkze_2.3's Avatar
Default Re: (Jason-K)
Should be both of the green ones...
Old Apr 3, 2007 | 09:47 AM
Jason-K's Avatar
both of the green ones? there are three i think, one on the upper radiator hose where it connects to the head, one under the distributor, and one on the thermostat housing itself, which one(s) is it? for sure?
anybody know plz help~!
Old Apr 3, 2007 | 07:16 PM
kulrevon's Avatar
There is two radiator fan switches. one is a primary and one is a secondary. The one that hawkze pointed out is the one for the temp gauge. The one by the thermostat and then there is another one on the front outlet.
The A switch is on the the thermostat housing. The B switch is in the front.
Switch A is a 203 degree and the B is a 223 degree
Modified by kulrevon at 11:29 PM 4/3/2007
Old Apr 3, 2007 | 07:31 PM
wle05's Avatar
Default Re: temperature sending unit (Hawkze_2.3)
Sorry to thread jack but how do those OBX rad hoses work ???
Old Apr 3, 2007 | 09:37 PM
Hawkze_2.3's Avatar
Default Re: temperature sending unit (wle05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wle05 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry to thread jack but how do those OBX rad hoses work ???
After you cut them to the proper size they function well as hoses.
chellerfl
Jul 13, 2016 07:43 AM
dman81
May 28, 2014 03:20 AM
b18Aaron
86
May 8, 2010 10:03 PM
intekragsr
Feb 27, 2003 02:14 PM
JDM_Type-R
Jun 16, 2002 08:31 PM
