Valves
Old Mar 29, 2007 | 03:48 PM
Smokey5176's Avatar
Default Valves
I think my valves need to be adjusted or replaced can some one help me on this last week befor i put my new clutch in my car didnt grap 4th gear and my motor reved up to 10 grand (this happend twice) and now i noticed at idel my motor it not so quite it kinda makes a ticking noise can some one give me some advice on this???
Old Mar 29, 2007 | 03:57 PM
jdmlude5
Guest
Posts: n/a
Default Re: Valves (Smokey5176)
well u could have bent them. well one time i did that **** and it knocked the nuts on the valve adjusters loose.
Old Mar 29, 2007 | 04:02 PM
Smokey5176's Avatar
Default Re: Valves (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">well u could have bent them. well one time i did that **** and it knocked the nuts on the valve adjusters loose.</TD></TR></TABLE>
will it expletive my car up if i drive with a bent valve or is it going to make me lose power
Old Mar 29, 2007 | 04:07 PM
bluedlude's Avatar
if you have a bent valve, then it would probably be a matter of time before it breaks and if that happens, you are extra fucked. pop the valve cover off and check it out. its not that hard and you will have peace of mind. if you dont want to adjust them, you can still check at least.
Old Mar 29, 2007 | 04:33 PM
Smokey5176's Avatar
Default Re: Valves (bluedlude)
is it a big job if they need to be adjusted??
Old Mar 29, 2007 | 05:13 PM
bluedlude's Avatar
heres the link to the DIY in the FAQ thread
https://honda-tech.com/zerothread?id=618786
i think its pretty straight forward. i know what im doing, so i can do mine in about 20 minutes, but it shouldnt take you more than an hour maybe two. just be patient and if you end up adjusting the valve lash just make sure you are triple checking the clearance before you close it all up again.
Old Mar 29, 2007 | 05:40 PM
mattsnooz's Avatar
local honda shop might have a flat rate. My local shop will do it for 88 dollars flat!
Old Mar 29, 2007 | 05:47 PM
bluedlude's Avatar
Default Re: Valves (mattsnooz)
****, id love to charge someone $88 for a valve adjustment .
Old Mar 29, 2007 | 06:00 PM
mattsnooz's Avatar
eh its better than the 2 hour labour some shops will try to charge ya. i was just offering a semi inexpensive way to get it done. It is easy though, i've done it and takes me less than 30 minutes after car is jacked and front driver side tire is off. I almost cried the first time i did it. it runs soo smooth after. oops... i wet myself
Old Mar 29, 2007 | 06:27 PM
Smokey5176's Avatar
if my valves are bent would i be able to tell with out taking the cover off???
Old Mar 29, 2007 | 06:31 PM
bluedlude's Avatar
i guess you could take the intake manifold and header off and look into the ports
or get a leakdown test done
Old Mar 29, 2007 | 07:40 PM
Rosko's Avatar
leakdown would prolly be the best bet, however I've seen a valve bend and the motor would still run fine only to have it break off a few days later. If ever again I even think I bent a valve they are all comin out and goin in the trash. I know from my own expierince how much damage can happen when a valve head pops off
NETAMI
Mar 19, 2006 06:45 PM
Baron55
Aug 9, 2005 03:27 PM
deconstruct
23
Jun 29, 2004 09:31 AM
rlj51
Apr 9, 2003 01:48 PM
GreenD
Apr 25, 2002 07:30 AM
