no more reverse
I've got a '94 VTEC. The Reverse just stopped working one day. All the other gears worked fine, the clutch was working fine, no fluid leak, nothing. It didn't work for about two more weeks. Then it just started working one day. I've never found out what was wrong with it but I haven't had a problem since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4 jdm lude »</TD></TR><TR><TD CLASS="quote">im not really sure maybe a synchronizer but that is about alli can think of </TD></TR></TABLE>
reverse has no synchro
the problem with the h trannies when you can't get into reverse is with the shift fork, it can get bent, there was a recall on them for problems with 5th gear.
My old prelude did this once, I just went caveman on it and eventually got it to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">
My old prelude did this once, I just went caveman on it and eventually got it to work.</TD></TR></TABLE>
isn't the 5th gear grind caused by a manufacturing defect w/ the fork? my reverse is an itch to get into sometimes. i just release the clutch and depress it again and it normally goes in. any thoughts on that?
mine dose the same.. miss 2nd to third and sometimes 4th to 5th... it sux.. no reverse also.. dose any one know the cost of the shift fork and where location it is.. this is my first prelude..
