ground control lowering
Old May 2, 2007 | 12:53 PM
honda_andy's Avatar
Default ground control lowering
hey, i have had my gc/koni coilovers on for a while now, the rears i had on for about 4 weeks now and its fine, but the fronts i have had on for a week and a half now and i still cant get it very low, how long does it need to settle, i have it more than 3/4 down and its still like a little more than a 2 finger gap in the front, any ideas?
Old May 2, 2007 | 04:06 PM
honda_andy's Avatar
anyone?
Old May 2, 2007 | 05:28 PM
rch022's Avatar
Default Re: ground control lowering (honda_andy)
drop it down all the way in the front and see how it looks
Old May 2, 2007 | 10:44 PM
honda_andy's Avatar
it almost is all the way, i only have about a finger gap between the spring and the collar.
Old May 3, 2007 | 08:00 AM
rch022's Avatar
Default Re: (honda_andy)
yeah i dont know what to tell you, i want to rock some GC's in the future and dont want to run into this problem, bump for more answers
Old May 3, 2007 | 08:43 AM
plikit's Avatar
is it possible you have the fronts and rears reversed?
Old May 3, 2007 | 08:50 AM
slammed95lude's Avatar
Default Re: (plikit)
It sounds like they are revesed, the Prelude on ground controls is supposed to be raked..(lower in the front than the rear).
Old May 3, 2007 | 10:49 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by plikit &raquo;</TD></TR><TR><TD CLASS="quote">is it possible you have the fronts and rears reversed? </TD></TR></TABLE>
Depends. If he got springs that are the same height then it wont matter. I have a 97 Prelude and just got my kit. All 4 springs are 8" high so I can swap the front to the rear. If he has the same then it shouldn't matter.
Old May 3, 2007 | 10:56 AM
95PreludeSi's Avatar
Default Re: (CAN97SH)
Also check the konis. What circlip setting are you using for the GC perch. I think you have like three options in the front and two in the rear. I've got mine on the lowest perch front and rear.
Old May 3, 2007 | 06:17 PM
honda_andy's Avatar
Default Re: (95PreludeSi)
ya all the springs are the same height, its 400lbs in the front and 320 in the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">Also check the konis. What circlip setting are you using for the GC perch. I think you have like three options in the front and two in the rear. I've got mine on the lowest perch front and rear. </TD></TR></TABLE>
even if its on the top circlip, im sure i can lower my car more than a 2-3 finger gap, cant i?
Old May 3, 2007 | 06:55 PM
bburtonsk8r2's Avatar
im rockin ground controls with red eibach springs and blue tokico struts... just bounce weight on the fender a few times to get it to settle, it doesnt take a week, i measured from the fender well to the ground to get the ride height right, i am running 225/50 16s so i cant lower mine too much, i would lower it all the way down and see where your at, they arent hard to adjust, just need a jack, a few sockets and a hex what size tires are you runnin?? make sure you dont bottom out your struts, i blew a kyb agx by slammin it all the way down, if it is used to riding at a certain height you can damage it by lowering it to low, if they are new you should be fine... keep adjusting and measuring to you see what you want. and then get a damn alignment, if you lived in md i could help you out
Old May 3, 2007 | 07:04 PM
BrockNB's Avatar
Default Re: (bburtonsk8r2)
AGX's are lifetime warentee.
Old May 3, 2007 | 07:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_andy &raquo;</TD></TR><TR><TD CLASS="quote">
even if its on the top circlip, im sure i can lower my car more than a 2-3 finger gap, cant i?</TD></TR></TABLE>
not sure, you should be able to jack the car up and change the clip without removing the assembly though.
Old May 3, 2007 | 08:09 PM
honda_andy's Avatar
trust me guys, ive banged on a few holes in this city enough to force them to settle already, still no go. i guess ill have to take a look at the circlip tommorow, thanks for all the replys, much appreciated. keep them coming
Old May 3, 2007 | 08:11 PM
spin_r_g's Avatar
Default Re: (BrockNB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrockNB &raquo;</TD></TR><TR><TD CLASS="quote">AGX's are lifetime warentee.
Not if you lower the car beyond 1.5 inches. It voids the warranty.
Old May 4, 2007 | 03:34 AM
BrockNB's Avatar
Default Re: (spin_r_g)
pretty sure there is no way they can tell. Like I live where the roads are ****** terrible and my struts bottom on alot. How can agx tell you they wont warentee then because your town sucks. Maybe your cars not even lowered.
Old May 21, 2007 | 02:32 PM
r_cade's Avatar
Default Re: (slammed95lude)
how much of a rake..? i just did the same install, 01 prelude, gc/ky.. front and rear springs were the same length but one was thicker.. put those in the front and it sits about 1.50" from tire to fender maxed out.. rear sits almost 3 inches maxed. it looks like a damn hot rod - my girl is kind of upset.. ha. i told her i didn't know anything about suspension..
any suggestions..?
jmart41791
Suspension & Brakes
61
Apr 26, 2010 03:55 PM
lsvtek
Suspension & Brakes
23
Apr 18, 2008 08:16 AM
2DoorBandit
Suspension & Brakes
Nov 7, 2005 10:30 PM
turbotime
Suspension & Brakes
19
May 16, 2005 07:58 AM
slowr6
Suspension & Brakes
Jan 27, 2005 05:12 AM
