Stock wheel offset
Old May 1, 2007 | 09:33 AM
ZXRider's Avatar
Default Stock wheel offset
What is the stock offset on a 1998 Prelude base wheels?
Also they are 16x7? or 16x7.5?
Thank you,
Old May 1, 2007 | 09:59 AM
jdizzle!
Guest
Posts: n/a
Default Re: Stock wheel offset (ZXRider)
search has been covered many times
Old May 1, 2007 | 10:58 AM
ZXRider's Avatar
Default Re: Stock wheel offset (jdizzle!)
Thanks, I found it.
so stock wheel size is
16 x 6.5
+55 offset.
205/50/16 tires
I'm looking at a set of wheels 17x7.5 with a +40 offset. If my calculations are correct that means I can mount these wheels without any rubbing issues...am I correct?
I'm adding an inch of width but subtracting from the offset so it compensates. I'm not sure tho lol.
Anyone know if I can run these without rubbing?
Modified by ZXRider at 1:06 PM 5/1/2007
Old May 1, 2007 | 12:45 PM
A Blue Lude's Avatar
Less offset will make the wheels stick out more. More wheel with will also make the wheels stick out more. +40 and 7.5 is definitely asking for fender rubbing to happen.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old May 1, 2007 | 01:25 PM
ZXRider's Avatar
Default Re: Stock wheel offset (A Blue Lude)
Wierd, I thought with the +40 offset the wheel will get pushed more inside the wheel well. Since the more + offset the more the wheel gets moved outward.
I just found this through search.
copied from: http://www.ottawaprelude.ca/ya...=2886
OFFSET:
6.5" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: You take the chance of rubbing the outside lip of the wheel well.
+38mm to +55mm ::: You shouldn't have any problems. Recommended Offsets for 6.5" Wide Wheels.
Larger than +55mm ::: You take the chance of rubbing the inside lining of the wheel well.
7" Wide Wheels w/ 4th & 5th Gen
Less than +38mm ::: Not Recommended
+38mm to +41mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well.
+42mm to +44mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well.
+45mm to +50mm ::: You shouldn't have any problems. Recommended Offsets for 7" Wide Wheels.
Larger than +51mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
7.5" Wide Wheels w/ 4th & 5th Gen
Less than +40mm ::: Not Recommended
+40mm to +43mm ::: Not Recommended if you are, or plan to be, lowered. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using any tire with an overall diameter larger than stock and/or with a tire width larger than 215.
+44mm to +47mm ::: This is a grey area if you are lowered, results vary depending on tire and/or drop. You take the chance of rubbing the outside lip of the wheel well. Wouldn't recommend using a tire with an overall diameter more than slightly larger than stock, you chances of rubbing increase.
+48mm to +52mm ::: You shouldn't have any problems. Recommended Offsets for 7.5" Wide Wheels.
Larger than +53mm ::: Not Recommend. You take the chance of rubbing the inside lining of the wheel well.
8" Wide Wheels w/ 4th & 5th Gen
Not recommended without enlarging or rolling outside lip of wheel wells. Some people have had success with running offsets larger than +48mm, but you are taking an expense risk.
Modified by ZXRider at 2:42 PM 5/1/2007
HamiltonRex
Oct 12, 2005 11:56 AM
torqueless
Jul 13, 2005 12:12 PM
silver_nteg
Jul 5, 2004 10:54 PM
JoeyBallzSI
Oct 20, 2003 03:04 PM
