o2 sensor
Old May 5, 2007 | 05:45 PM
Smokey5176's Avatar
Default o2 sensor
my cheak engine light came on and i hooked it up to the computer and it sad bad 02 sensor.will anything happen if i dont change it right away my engine light also went off after 2 weeks too.
Old May 5, 2007 | 05:54 PM
preludeMOM's Avatar
Default Re: o2 sensor (Smokey5176)
I dont know that much, But i thought it just senses air/fuel, like...if its broke, you're car will defaultly waste alot of gas because it can't determine how much your car needs?
Old May 5, 2007 | 06:07 PM
51ludeguy's Avatar
nothing bad will happen, except for your mpg will go through the floor......Go to sparkplugs.com and get an OE Denso primary o2 sensor for 40 bucks.
Old May 5, 2007 | 06:31 PM
preludeMOM's Avatar
h22blackhatch -
I have 1992 prelude with h22a swap, that OE densor sensor will be good for me?
*MINE IS ALSO BROKE LOL*
Whats the difference between:
- Denso OE identical O2 sensor $80+
- Denso Uninversal 02 sensor $45
Old May 5, 2007 | 09:27 PM
MooJenLude's Avatar
One is OEM direct replacement and one is just a universal...I'd go with oe just to be safe
Old May 5, 2007 | 09:56 PM
zirac50's Avatar
Default Re: (BurberryLude)
Hey I have same situation, I had code for 02 so I replaced it
my 02 is new, (denso) from autozone, I have catback exhaust, headers (not so high class) came from base moded it to fit on SH. In other words, it was welded cuz i believe the SH has longer downpipe.
Anyway, code keeps coming back, reseted many times, shows up after few days again. Helms say either exhaust leak or bad primary O2.
1. Should I suspect the O2 sensor even it's new?
2. Should I check the header for air leak?
Old May 6, 2007 | 09:38 AM
51ludeguy's Avatar
Here is the link:
http://sparkplugs.com/results_app.asp
You want the OE Denso one that is 40 bucks.
Zirac- I'll let someone else give you a more solid answer....
HCivicEx2001
Honda Civic (2001 - 2005)
Jul 15, 2019 02:54 PM
etherspeed
Jun 9, 2008 06:06 AM
Nizzy
May 22, 2003 03:58 PM
kapolani
Jul 9, 2002 11:05 AM
