distributor problem? video
Old May 6, 2007 | 05:45 PM
squarepusher's Avatar
Default distributor problem? video
http://www.diorsplace.com/MVI_1644.avi
i have a 97 h22, running previous year distributor from 94, and was wodnering if that is a problem at all that could be causing the above video.
notice, the engine surges from about 1.2-2.2K RPm
ideas?
Old May 6, 2007 | 05:51 PM
vinuneuro's Avatar
Default Re: distributor problem? video (squarepusher)
Vacuum leak, fast idle valve or idle control valve. Most likely fast-idle valve if you haven't been messing around in there.
Old May 6, 2007 | 07:29 PM
Default Re: distributor problem? video (vinuneuro)
ahh, vacuum leak it is, a hose is complete broken at the IM
does anyone know how the Skunk2 IM work?
i see the one hose that is completely broken, but the other slot has a fastener thing to keep it closed, but that seems to be broken also (cant see it int he pic)
Old May 6, 2007 | 07:40 PM
vinuneuro's Avatar
Glad you found the problem. The Skunk2 manifold is not good at all..the Euro R manifold is an outstanding one though.
Sic_DA_Nine
May 6, 2006 05:41 AM
iukaman420
May 4, 2005 02:56 PM
silver89civic
Mar 13, 2005 06:29 PM
