Harness
Old May 5, 2007 | 05:56 PM
Bambinoh's Avatar
Default Harness
Can you use a H23 harness on a H22a engine ?? ECU = H22a ??
Old May 5, 2007 | 09:51 PM
MooJenLude's Avatar
Edited...
Modified by BurberryLude at 11:02 AM 5/6/2007
Old May 5, 2007 | 09:55 PM
Altilude's Avatar
Default Re: Harness (Bambinoh)
yeah the engine harness is fine, but you will have to run 2 extra wires, one for the vtec pressure switch, and the other for vtec solenoid - a4, and d6. it's much easier than chucking in a whole new harness. ecu = p13.
the red search button is also your friend.
Old May 5, 2007 | 11:13 PM
H22A in Ohio's Avatar
Default Re: (BurberryLude)
Yes the Si's are actually wired for VTEC from the factory. There is a spot to plug the wires into by the fuse box under the hood. I would recommend just running the wires straight to the ECU though.
Old May 5, 2007 | 11:43 PM
outlawstar27's Avatar
not all are prewired. but yes you can use the h23 harness on an h22a engine. just need the vtec plugs and wires.
92nahatch
Dec 27, 2007 09:39 AM
boosted_teg93
Oct 24, 2004 06:54 PM
sicklude94
Sep 28, 2004 08:42 PM
HeineKEN22
Dec 7, 2003 01:35 PM
mstsh80
Jul 1, 2003 12:49 PM
