El Cluster Conversion Problem
Old May 17, 2007 | 12:54 PM
Ludster's Avatar
Default El Cluster Conversion Problem
Just swapped in an 94 EL Cluster and dash harness. Now my Dimmer relay just buzzes constantly .
My Parking lights/High beams/turn signals don't work. My headlights stay on and the high beam indictor on the cluster is lit, but dim..
I've been troubleshooting for about a week now, and no dice. I've changed out flasher relay, Headlight relay, and dimmer relay. I've jumped the connections on the fusebox to see if my turn signals would light up and they do.
Anybody ever heard of anything like this?
Old May 17, 2007 | 12:59 PM
outlawstar27's Avatar
hmm...the only problems im having right now are my light indicators. if i signal left the hazzards turn on and vice versa. but everything outside works though. i was told to ground a black wire from the plug that is NOT connected to anything. its on the passenger side. did you do that already>??
Old May 17, 2007 | 01:04 PM
Ludster's Avatar
Default Re: (outlawstar27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outlawstar27 &raquo;</TD></TR><TR><TD CLASS="quote">hmm...the only problems im having right now are my light indicators. if i signal left the hazzards turn on and vice versa. but everything outside works though. i was told to ground a black wire from the plug that is NOT connected to anything. its on the passenger side. did you do that already&gt;??</TD></TR></TABLE>
I did ground the blk wire for that 3-pin connector. I've checked all fuses multiple times.
Old May 18, 2007 | 03:44 PM
shaylude's Avatar
Default Re: (Ludster)
yeah, i just bought a 95' with EL gauges and when i would signal right, the hazards would come on, but now they dont come on..i guess it fixed itself..who knows.
but im wanting to swap the EL's from my 95 to my 93 and then swap the (non el's) from my 93 to my 95..i read their was an instruction guide on preludepower dot com but i couldn't find it.
Proud Virginian
Jun 7, 2016 03:00 PM
Ken99287
11
Mar 4, 2012 11:48 AM
UnleashedEJ1
Jan 31, 2011 01:36 PM
PGH95EG8
25
Oct 29, 2009 12:10 PM
nihad
Mar 30, 2008 09:41 AM
