engine bay hot
Old May 20, 2007 | 06:11 PM
outlawstar27's Avatar
Default engine bay hot
ok guys. im just finally finishing up my lude swap. its a 92 with a jdm h22a. my vtec is not hooked up. thats my only check engine light as of now. i still have a surging idle that i cant figure out. anyways to me it seems like the engine bay gets real hot! its hot enough to notice that something is up but the gauge marks normal temps. the fan is wired directly because it wouldnt turn on running it normal. but is everyones engine bay that hot?
Old May 20, 2007 | 07:15 PM
BlownH23a
Guest
Posts: n/a
*Smacks self in forehead* you do understand that engines generate a whole lot of radiant heat right...
as for the surging idle SEARCH its been covered 99999^99 times
if your car is not burning, or your engine is not overheating..who cares.
Old May 20, 2007 | 07:25 PM
m00nr0ck Si's Avatar
Default Re: engine bay hot (outlawstar27)
-Bleed your coolant <open radiator cap and let it run for 30 min. or so>
-check your cam and ignition timing
-check your vac. hoses
-check intake manifold and tb gasket
Old May 20, 2007 | 07:31 PM
yes i do know engines put out heat. but this heat seems not normal. coolant was bled but ill do it again. cam and timing is good. hoses seem fine. tb gasket is new
bikersquid
Honda Civic (2001 - 2005)
Jan 3, 2018 01:37 PM
fa5VSeg8
Mar 8, 2011 03:29 PM
chad
Jun 24, 2010 04:28 PM
bboylito
Jul 9, 2004 01:51 PM
aeon
Apr 12, 2004 05:40 PM
