Bleeding Sequence
Old May 16, 2007 | 07:00 AM
spun311's Avatar
Default Bleeding Sequence
Does anyone know the brake bleeding sequence. Car is a 94 Prelude Si, if that makes any difference. Thanks.
Old May 16, 2007 | 07:30 AM
93sivtec's Avatar
I belive u start the furthest from the master.Get a manual..... haynes or chilton, to be sure
Old May 16, 2007 | 08:32 AM
4WSi_guy's Avatar
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">I belive u start the furthest from the master.</TD></TR></TABLE>
this is correct as with most cars...start at RR then LR then RF then LF.......you should also have bench bled the Master Cylinder..
Old May 16, 2007 | 10:58 AM
user 9782082308's Avatar
Default Re: (4WSi_guy)
Hondas and other imports split up the brakes into two systems by use of their 4 way perportioning valve. Opposite corners of the car are linked together that way you can never loose the front brakes. The bleed sequence is: r rear, l front , l rear, r front.
Old May 16, 2007 | 11:08 AM
4WSi_guy's Avatar
Default Re: (racerx)
I stand corrected:
BRAKE SYSTEM
Article Text
1993 Honda Prelude
For Cadi Centre Nsk CA 95051
Copyright © 1998 Mitchell Repair Information Company, LLC
Sunday, July 08, 2001 11:22AM
ARTICLE BEGINNING
1993 BRAKES
Honda Brake System
Prelude
DESCRIPTION
Prelude uses front disc brakes. Rear brakes may be either
disc type or self-adjusting drum type. Parking brake cable mechanism
applies rear brakes.
BLEEDING BRAKE SYSTEM
BLEEDING PROCEDURES
Raise and support vehicle. Fill master cylinder to maximum.
Check fluid level after bleeding each wheel position. Bleed brakes in
sequence. See BRAKE LINE BLEEDING SEQUENCE table.
BRAKE LINE BLEEDING SEQUENCE TABLE
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAA
Application Sequence
Prelude ................................... RR, LF, LR, RF
Old May 16, 2007 | 11:48 AM
Jason-K's Avatar
In my chiltons it sais FL, RR, FR, LR
I guess the book is wrong?
Old May 16, 2007 | 12:28 PM
4WSi_guy's Avatar
Default Re: (Jason-K)
somethins wrong cuz you got 3 rears there.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason-K &raquo;</TD></TR><TR><TD CLASS="quote">FL, RR, FR, LR</TD></TR></TABLE>
Old May 16, 2007 | 06:41 PM
spun311's Avatar
Thanks guys. I finally found my helms manual under a pile of parts.
Old May 16, 2007 | 11:11 PM
Jason-K's Avatar
Default Re: (spun311)
how is that three rears?
fl= front left
rr= right rear or rear right
fr= front right
rl= rear left
Old May 17, 2007 | 04:02 AM
SnlpeR's Avatar
rrflrlfr
Old May 17, 2007 | 05:13 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx &raquo;</TD></TR><TR><TD CLASS="quote">Hondas and other imports split up the brakes into two systems by use of their 4 way perportioning valve. Opposite corners of the car are linked together that way you can never loose the front brakes. The bleed sequence is: r rear, l front , l rear, r front.</TD></TR></TABLE>
yup its actually called diagonal split
rps_ak
May 29, 2007 05:37 PM
4cylsturbo
Jun 20, 2006 03:16 PM
ekian
Feb 16, 2006 07:48 PM
ekian
13
Feb 16, 2006 06:24 AM
oMek
Nov 5, 2003 02:26 PM
