Cooling problem - how bad is this
Old May 21, 2007 | 03:31 PM
fubar's Avatar
Default Cooling problem - how bad is this
Leaking coolant pretty badly. Leak is in the hose highlighted in the photos below. How bad is this? Any ideas how much this would cost to get fixed?
(1999 Prelude with 130,000 miles)
Modified by fubar at 7:54 PM 5/21/2007
Old May 21, 2007 | 03:35 PM
ninja 6's Avatar
Default Re: Cooling problem - how bad is this (fubar)
run yourself over to honda, buy a new hose
Old May 21, 2007 | 03:45 PM
SnlpeR's Avatar
had to replace that same hose too on my car
its not very hard at all
just buy the right hose with the right diameter
about 3 ft will be enough
both ends are not hard to reach
Old May 21, 2007 | 03:54 PM
BlownH23a
Guest
Posts: n/a
mine exploded a couple months ago, i replaced it with a high pressure line... did a cut and advance for a temp fix.
Old May 21, 2007 | 04:30 PM
Altilude's Avatar
Default Re: (BlownH23a)
I had to repair that once on the highway! split right around where you circled, and dumped a bunch of coolant (and fast!), just prior to that I was having overheat problems (radiator related) so lucky for me I had a Jug of coolant in the trunk! On the highway, I cut off the split bit, and managed to stretch it just enough to stay on, then replaced it as soon as I could, along with some of the other older rubber. i'd change it up soon, so much easier in your driveway than on the side of a road with cars whizzing by. makes you feel like your pants are down. but that's a different highway story.
Old May 21, 2007 | 05:15 PM
russlan44's Avatar
Default Re: (Altilude)
i will be replacing my soon, hope it wont go out on me, 2 1/2 mounts and im out the house, moving in my own. my dad is tripping too much if i work on car in garage.
Old May 21, 2007 | 06:01 PM
fubar's Avatar
Default Re: (SnlpeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnlpeR &raquo;</TD></TR><TR><TD CLASS="quote">had to replace that same hose too on my car
both ends are not hard to reach</TD></TR></TABLE>
Good to hear that it won't be a tough fix. How many miles did you have on your lude when you replaced the hose?
Old May 21, 2007 | 06:26 PM
BlownH23a
Guest
Posts: n/a
Default Re: (russlan44)
sock your dad in the face and tell him you could be out doing drugs(more then usual) and having sex with prostitutes(dirty ones anyway).
Old May 21, 2007 | 07:14 PM
I want to be in your sig's Avatar
lol mine went out a few months ago and in the exact same spot. It was approx the same mileage too. Mine went out at at around 130,000 miles. Yea, just replace it.
Old May 21, 2007 | 08:25 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">sock your dad in the face and tell him you could be out doing drugs(more then usual) and having sex with prostitutes(dirty ones anyway).</TD></TR></TABLE>
hahahahaahhha My new one...
Old May 21, 2007 | 11:25 PM
SnlpeR's Avatar
about 120K
Old May 21, 2007 | 11:33 PM
russlan44's Avatar
lol i dont really care 2 more mounts and im out to my own
Old May 22, 2007 | 05:13 AM
flyrod's Avatar
Are you sure that's coolant? It looks like oil from a leaking seal (like on the intake cam plug) just above that hose.
Old May 22, 2007 | 06:09 AM
Lewdin' Incognito's Avatar
Default Re: (flyrod)
3/4" heater hose from AutoZone will fix that until you get a new formed hose in, by the way - where's your clamp that is supposed to be there?
Old May 22, 2007 | 03:00 PM
fubar's Avatar
Default Re: (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">3/4" heater hose from AutoZone will fix that until you get a new formed hose in, by the way - where's your clamp that is supposed to be there?</TD></TR></TABLE>
Not sure where the clamp is... is it necessary to have one there?
Old May 22, 2007 | 03:19 PM
bluelude2.3's Avatar
Yes there should be a clamp there. Oh yeah mine blow out at 200,000 miles.
lilshady6796
Jan 15, 2009 11:02 PM
EG9_808
Sep 1, 2008 06:16 PM
sdinteg
Sep 17, 2007 06:31 AM
zort_zrt
May 25, 2004 04:15 AM
tFUnK
Jan 2, 2003 12:56 AM
