Accel injector issue????
Old May 17, 2007 | 07:58 AM
ericdachampion86's Avatar
Default Accel injector issue????
I just bought a set of accel fuel 310cc fuel injectors and a mr. gasket g-sport fuel rail. Everything bolted together great with the exception of the wiring on the injectors. The injectors did not come with and wiring and my stock harness will not fit them. Has anyone ran into this before??? I called accel and left a voice message they haven't called me back yet. Do i have the wrong injectors or can i get clips for them somewhere. . . Damn ebay....
Old May 17, 2007 | 08:21 AM
BlownH23a
Guest
Posts: n/a
wasnt ebays fault...whats the part nbr?
Old May 17, 2007 | 09:15 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Accel injector issue???? (ericdachampion86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">wasnt ebays fault...whats the part nbr?</TD></TR></TABLE>
More importantly why did you buy 310cc injectors?? What motor is this for????
Old May 17, 2007 | 01:36 PM
its for an mildly modified h22a. One of my stock injectors went bad so i went with these. Thanks guys but i finally figured it out. i have to use the wiring clips from an obd1 harness.
Old May 17, 2007 | 01:37 PM
Default Re: (ericdachampion86)
yea its not ebays fault. i should have done more research before i bought the part. The part # is 150132.
Old May 17, 2007 | 07:40 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericdachampion86 &raquo;</TD></TR><TR><TD CLASS="quote">its for an mildly modified h22a. One of my stock injectors went bad so i went with these. Thanks guys but i finally figured it out. i have to use the wiring clips from an obd1 harness. </TD></TR></TABLE>
So is this for an OBD1 or OBD2 motor?? Cuz if its obd1 then you're going backwards...
Old May 18, 2007 | 09:25 PM
Default Re: (cb7-R)
its an obd 2 motor.
Old May 18, 2007 | 09:50 PM
ProjectTib's Avatar
just out of curiosity I have an OBD1 H22A1... do you know what size my stock injectors are? and if im doin some mild motor upgrades such as intake mani, throttle body, fuel rail, VAFC, I/H/E... should I upgrade them?
Old May 19, 2007 | 06:16 AM
pinecone's Avatar
Default Re: (ProjectTib)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectTib &raquo;</TD></TR><TR><TD CLASS="quote">just out of curiosity I have an OBD1 H22A1... do you know what size my stock injectors are? and if im doin some mild motor upgrades such as intake mani, throttle body, fuel rail, VAFC, I/H/E... should I upgrade them?</TD></TR></TABLE>
No need your stock injectors will flow enough for that little bit of power.
You bought injectors that were 20 cc's over stock, that if they are injectors from an h22a4. If the motor is an h22a they are 345cc injectors.
Old May 23, 2007 | 11:15 AM
Default Re: (pinecone)
I didn't want to go way big cause the engine is mostly stock. The injectors that were in the car were h22a4 so the accel are slightly larger, which is what i wanted. Really the only reason i changed to the accels are cause i got such a good deal on them. Well that and i thought one of the stock ones was bad.
lightning
Jul 15, 2006 03:21 PM
the.hamburglar
Mar 11, 2006 06:10 PM
INTEGRA_boy
Dec 13, 2005 12:22 PM
hondadriver
Feb 16, 2005 06:38 PM
ATS*Mark
Apr 8, 2004 01:34 AM
