suspension problem
Old May 18, 2007 | 03:12 PM
fubar's Avatar
Default suspension problem
The front right of my car is at least 1/2 inch lower than the left side... what could be causing this?
(I drive a 99 Prelude, base model. Recently had Prokit springs and Koni Sports installed, however the uneven ride height was a preexisting condition)
Old May 18, 2007 | 03:24 PM
m00nr0ck Si's Avatar
Default Re: suspension problem (fubar)
every honda Ive ever owned had a slight lean to the driver side ....I believe this is heavily due to the fact that the engine ,steering column,gas tank all reside on this side of the car.
Old May 18, 2007 | 05:15 PM
fubar's Avatar
Default Re: suspension problem (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">every honda Ive ever owned had a slight lean to the driver side ....I believe this is heavily due to the fact that the engine ,steering column,gas tank all reside on this side of the car.</TD></TR></TABLE>
I should have said passenger side... the front passenger side is lower than the left drivers side.
Old May 18, 2007 | 05:44 PM
ludeing1's Avatar
the fuel tank isnt on the left side... its in the middle right under the rear seats. and you forgot to say anything about the drivers weight thats constantly on that side while the suspension is working.
edit : and fubar did you install your kit?
Old May 19, 2007 | 07:05 AM
fubar's Avatar
Default Re: suspension problem (ludeing1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeing1 &raquo;</TD></TR><TR><TD CLASS="quote">
edit : and fubar did you install your kit?</TD></TR></TABLE>
No, I had a shop install the springs and shocks.
stevenk
Suspension & Brakes
12
Sep 26, 2008 08:49 AM
SWC
Suspension & Brakes
Jun 9, 2006 04:06 AM
Flux
Oct 3, 2005 02:58 PM
unknown0001
Nov 10, 2004 08:10 AM
blk97lude
Jul 2, 2003 08:52 AM
