Header wrap
Old May 20, 2007 | 06:21 AM
kornerk12's Avatar
Default Header wrap
Is there an advantage to running this if the header is already ceramic coated ? How much will it normally decrease underhood temps ? I have heard it can crack a header, is that true ?
Old May 20, 2007 | 07:05 AM
97Preludeguy's Avatar
Default Re: Header wrap (kornerk12)
The only time that most people condone wrapping a header is if the header in question is made stainless steel, other then that, it's best not to mess with the stuff
EDIT: As far as under-hood temps go, a lot of places advertise 70%. I myself have tested it and seen about a 50% drop in my application
Old May 20, 2007 | 10:27 AM
Speedra500's Avatar
Default Re: Header wrap (97Preludeguy)
the wrap will greatly reduce temperatures when compared to ceramic coatings. However most ceramic coated headers are not stainless in which they would probably rust through if wrapped for a long time.
Old May 20, 2007 | 11:07 AM
zirac50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">Is there an advantage to running this if the header is already ceramic coated ? How much will it normally decrease underhood temps ? I have heard it can crack a header, is that true ? </TD></TR></TABLE>
I have ceramic and it;s being wrapped. It works OK!
I am looking forward to stainless steel though. ceramic it flakes.
Old May 20, 2007 | 11:19 AM
E-Money's Avatar
Default Re: Header wrap (zirac50)
there are some downsize to wrappings, i would only wrap it if it was huge investment on a high end manifold. sometimes when you wrap them, moisture gets caught in them and puts a hole right through them.
but for any DC, Megan, etc.. i would not worry bout it. they cool down really fast.
Old May 21, 2007 | 05:07 AM
mattsnooz's Avatar
Default Re: Header wrap (E-Money)
from some searching and input from H-T i would say "no" to wrapping headers.
i'd worry about heat shielding things outside header like ac lines, cooling lines etc. like the above said the headers cool down fast and aslong as they arn't close to meltable hoses then ur fine. trapping heat inside header does help with performance. so if moisture wasn't an issue wrapping would be practical though.
Old May 26, 2007 | 10:10 AM
MrITR#0168's Avatar
Default Re: Header wrap (mattsnooz)
I just bought a supercharger and instead of running the after cooler i am running a intercooler. I was wondering if it is safe to wrap by down pipe and so on..all the pipes? The pipes are made of aluminuim. I was planning to buy the get the heat wrap and the HT Silicone Coating spray that DEI sells. Just wanted to know if its a good idea or not. thanks
d16Booger
29
Mar 4, 2009 05:19 PM
Capo dei Capi
Dec 6, 2007 08:06 PM
itr1244
Welding / Fabrication
Sep 4, 2006 09:04 PM
608 Gangsta
12
Apr 2, 2006 11:09 PM
ImporttRacerr555
Nov 25, 2003 02:13 PM
