Help! ASAP!
Old May 17, 2007 | 12:56 PM
Lubriel609's Avatar
Default Help! ASAP!
hey guys, ive been a member fr a while but am still a noob, anyways, i have a problem with my clutch on my 92 prelude, its fairly new and i recently replaced the slave and master cylinders, but today, i was losing resistance on the clutch, and after a while, lost almost all resistance and was unable to get it into gear, it finally started working after a few tries. any ideas? need help soon!
thanks
Old May 17, 2007 | 12:57 PM
Ludster's Avatar
Default Re: Help! ASAP! (Lubriel609)
Make sure you have clutch fluid and you bleed out all the bubbles.
Old May 17, 2007 | 01:00 PM
Lubriel609's Avatar
thanks, i was thinking about bleeding the clutch. more suggestions are still welcomed
Old May 17, 2007 | 01:19 PM
AndyD's Avatar
Well, first thing to do is see if there is any brake fluid in the clutch master cylinder reservoir.
Old May 17, 2007 | 01:25 PM
Lubriel609's Avatar
Default Re: Help! ASAP! (AndyD)
there is brake fluid in there
Old May 17, 2007 | 01:32 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubriel609 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i was thinking about bleeding the clutch. more suggestions are still welcomed</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubriel609 &raquo;</TD></TR><TR><TD CLASS="quote">there is brake fluid in there
If there is brake fluid in there. Then correct, try bleeding the clutch there maybe air in the system.
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
KloC 95 EG
Mar 13, 2006 09:18 PM
R.a.w.
May 18, 2005 03:41 PM
AlphaQup
Nov 13, 2004 12:10 AM
juniordc2
Jul 2, 2002 08:33 AM
