G23 Code 17 on deceleration
Old May 22, 2007 | 05:54 AM
BoostedH23Accord's Avatar
Default G23 Code 17 on deceleration
94 Accord H23/F22 Accord ECU
As the post title says, I'm throwing code 17 (injector error) when I let off the gas and decelerate.
Has anybody had this issue before? Would the injectors need to be replaced or just cleaned? I tried the fuel additive (injector cleaner) but that has not done anything. When I start the car there's no CEL, but if I allow the car to decelerate by letting off the gas I throw the code. If I accelerate quickly I also will throw that code.
Thoughts?
Old May 22, 2007 | 07:24 AM
AmauryR's Avatar
Default Re: G23 Code 17 on deceleration (BoostedH23Accord)
IIRC Code 17 is the VSS (Speed Sensor), a buddy of mine just threw a code 17 on his car after he did his swap.
ref: https://honda-tech.com/zerothread/1901557
-l8r
Old May 23, 2007 | 02:16 AM
Default Re: G23 Code 17 on deceleration (AmauryR)
Thanks, I must have looked at the wrong code when I looked it up.
Old May 23, 2007 | 02:25 AM
pentaq's Avatar
Most probably the VSS plug has loose pins inside.
Old May 23, 2007 | 03:01 AM
CHK4TIX's Avatar
Default Re: G23 Code 17 on deceleration (pentaq)
it could be the connector to the vss isnt secure or as happened to mine, the little tab that the bolt goes through is broken and every time you accelerate the vss pops out just a little. Then when you slow down it catches again and sends the code.
bcintron95
Aug 26, 2013 06:08 PM
O RLY
Jul 6, 2010 02:06 PM
BoostedH23Accord
May 23, 2007 02:16 AM
Herminator
Jun 28, 2003 03:45 AM
