Ball Joint Help...please
Old Jul 21, 2007 | 03:10 PM
93sivtec's Avatar
Default Ball Joint Help...please
Any tricks tto getting the ball joints out and in?They are front lower on the 4th gen.I dont have a tool,Im gonna just hammer them out and in,has anybody done this and if so do you have anytips?Thanks alot
Old Jul 21, 2007 | 03:16 PM
xxmastermindxx's Avatar
Default Re: Ball Joint Help...please (93sivtec)
i use a ball joint separator. basically looks like a fork, you stick it in as far as it goes where the ball joint is, and hammer it till it pops out. i've done this 30+ times, no damage whatsoever. there is a puller tool that works too, i just use the fork.
Old Jul 21, 2007 | 03:56 PM
93sivtec's Avatar
Im sorry I wasnt clear.....Im replacing the ball joint....I have a seperator,but how the hell do u get them out of the lower controll arm....they look like they are pressed in.Ive heard that u can just hammer them in and out but its not easy.
Old Jul 21, 2007 | 03:57 PM
93sivtec's Avatar
Ive searched the archived threads and couldnt find any write ups,but I know there has to be one.
Old Jul 21, 2007 | 04:07 PM
saikou's Avatar
There is a write-up:
https://honda-tech.com/zerothread?id=1932061
Old Jul 21, 2007 | 04:20 PM
93sivtec's Avatar
Thanks alot , that was what I was looking for....I need a ball joint press,well its off to harbor freight.Thanks
Old Jul 21, 2007 | 05:02 PM
snobordboy's Avatar
Moderator
Default Re: (93sivtec)
I would just bring the arms to a machine shop or auto shop with a press, give a mech a 12er of cold beer would probably do it
Old Jul 22, 2007 | 07:01 AM
bluedlude's Avatar
Default Re: (snobordboi)
my lower ball joint was fused into the LCA. i ended up mashing the end of the balljoint trying to press it out myself. i ended up having to take it to a mahcine shop. as far as i know, honda doesnt sell just the ball joint, so i had to buy a new knuckle. $170 + machining + $90 for a new wheel bearing because the old one was fused into the old knuckle . be very careful with the ball joint.
Old Jul 22, 2007 | 08:47 AM
93sivtec's Avatar
Yeah that sucks.....look at the write up....forget the machine shop...besides when was the last time you got to beat the **** out of your car with a 5lb sledge hammer?
Old Jul 23, 2007 | 10:12 PM
93sivtec's Avatar
Holy cow that was no joke....haha.I only did one side tonight because I got off to a late start and the press I had wasnt working out.....so I ended up pounding it with a hammer and a piece of brass(long cylinder),and got it in there after about 15 min of gentle tapping with a sledge.Ill do the other side tommorrow before work,and then my tie outter tie rods next week,maybe.Any tips on those?They look tricky.
Old Jul 23, 2007 | 11:24 PM
jmai86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Holy cow that was no joke....haha.I only did one side tonight because I got off to a late start and the press I had wasnt working out.....so I ended up pounding it with a hammer and a piece of brass(long cylinder),and got it in there after about 15 min of gentle tapping with a sledge.Ill do the other side tommorrow before work,and then my tie outter tie rods next week,maybe.Any tips on those?They look tricky.</TD></TR></TABLE>
Outer tie rods are a breeze. Took me 10 min per side. You just need the ball joint seperator to pop off the tie rod joint, then unscrew from the inner rod and replace.
The inner tie rod is a bitch though.
Old Jul 24, 2007 | 08:36 AM
93sivtec's Avatar
Do u need to get realigned afterCause if so I will do next week.
M15
Mar 16, 2006 08:09 AM
rasinhell
Feb 3, 2005 01:47 PM
Vp Special K
17
Jan 6, 2004 02:08 PM
speed_racer012
20
Nov 29, 2003 06:54 PM
97hb
Mar 9, 2002 11:31 PM
