Some odd electrical problems with ATTS
Hey, I'm having some odd electrical problems with my ATTS. My first problem is that codes won't erase, the light is on as soon as the ignition is turned on. My second problem is that I get different sets of codes with different control units.
I know most of you probably have little or no experience with ATTS, but in general what usually causes these sorts of symptoms?
I've got the helms, but it isn't much help because I don't know which codes to troubleshoot since they're different depending on which control unit I use.
Codes are for:
-pgmfi-communication line
-fail-safe relay
-map sensor
Codes are for:
-fail-safe relay
-map sensor
Because it's a damn pain troubleshooting electrical crap like this. Esp when a lot of the procedures end in check open between control unit and atts unit, etc. These harnesses connect from the pass side footwell to driverside fusebox area, and also across the firewall to the atts unit. LOL
Meh, I've thought about just swapping in a jdm h22 w/ m2b4, but I'm not sure if I'm going to keep the Prelude or not. I've had my eye on those 95 SiR-G Type R VTEC RS V-spec 's for a while now.
Fwiw, ATTS works very very well when it's working and seems like it's pretty reliable for most people for the most part.
WOOOOOOOT!!!!!! After a year of just saying blah bc I couldn't get the relay I need to out bc of inaccessibility, I solved my problem !!!
The first two relays are completely missing in USDM ludes, even the holder. I was trying to get the wrong relays out! Btw, the ABS and ATTS relays in the diagram are labeled backwards. Now hopefully, stealer won't charge an insane amount for this small relay.
If you're trying to get one of these relays out and the white cover on top seems like it gets in the way, it does. Just push on it upwards and it just snaps off. I don't know why Honda even put it there.
unstopabledj
Sep 19, 2004 08:04 PM
