air filter
Old Jul 20, 2007 | 11:56 AM
Stellarhark's Avatar
Default air filter
my air filter that came with my aem cold air needs replacement... where can i get something cheap that will last? (95 vtec)
Old Jul 20, 2007 | 11:57 AM
Toe_Knee's Avatar
Default Re: air filter (Stellarhark)
k&n
Old Jul 20, 2007 | 12:01 PM
viper_boy403's Avatar
AEM filters are washable
Old Jul 20, 2007 | 12:02 PM
Toe_Knee's Avatar
Default Re: (viper_boy403)
Isn't that only some of them? They have cleaning kits too.
Old Jul 20, 2007 | 12:09 PM
Default Re: (Toe_Knee)
yea its washable .. its just it has like 100k on it needs to be replaced
Old Jul 20, 2007 | 12:10 PM
nonvteclude's Avatar
the new aem filter is killer. constructed basically the same as the k&n just without needing to oil it. i recommend the aem filter over the k&n now.
Old Jul 20, 2007 | 03:05 PM
Missing Gears's Avatar
Default Re: (nonvteclude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">the new aem filter is killer. constructed basically the same as the k&n just without needing to oil it. i recommend the aem filter over the k&n now. </TD></TR></TABLE>
k+n and aem are not the best filtering options out there.
you need to be careful using a non-oiled filter (especially on turbo applications) as they do not filter as well as oiled filters.
if you want to go w/ a dry filter and have the best protection possible out of a dry filter go w/ AMSOIL NANOFIBER FILTERS. they make filters for several oem applications as well as any size cone filter you would need w/ any size inlet. you simply tap them on the ground or blow them out w/ compressed air to clean them.
if you want the best oiled filter, go w/ AFE PROGUARD 7 filters. they are washable and you can get the cleaning/oiling kit w/ it. they also come in any size cone filters and should also come in oem direct fit applications as well.
most guys in the import market are unaware of these brands as AEM and K+N are "trendy" in this market. but i assure you AFE and AMSOIL make the best air filters available period. filtering protection and airflow are EXTREMELY important in a turbo diesel engine as well as any other turbo application that is expected to run for many hundreds of thousands of miles so experienced diesel guys only run the best air filters available. i believe you will find the prices reasonable and fair compared to the trendy import marketed k+n/aem filters as well
Old Jul 24, 2007 | 04:04 AM
petebog's Avatar
Default Re: (Missing Gears)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Missing Gears &raquo;</TD></TR><TR><TD CLASS="quote">if you want the best oiled filter, go w/ AFE PROGUARD 7 filters. they are washable and you can get the cleaning/oiling kit w/ it. they also come in any size cone filters and should also come in oem direct fit applications as well. </TD></TR></TABLE>
They don't seem to be available (in oem form anyway) for the Prelude though? From what I've read they seem to be aimed at diesel engines mainly, and if you go to the product page on their site there's no Prelude listed.
JDMTEG98
Aug 27, 2002 07:19 AM
feriocious
Aug 6, 2002 06:03 PM
Fuster_Cluck
Apr 7, 2002 06:05 PM
Zulu888
Sep 5, 2001 06:17 AM
ALF
Jul 4, 2001 08:59 PM
