Replace main bolts
Old Jul 17, 2007 | 08:08 PM
lude98SH's Avatar
Default Replace main bolts
I just removed my girdle and main caps in order to install my balance eliminator kit. I know im supposed to technically replace my main studs, is it 100% necessary ? I have a set of ARP main studs, however i have been told that due to the higher torque oil clearence may change with these studs.
Old Jul 17, 2007 | 08:13 PM
Missing Gears's Avatar
Default Re: Replace main bolts (lude98SH)
stick w/ the stock oem bolts, youll be fine to reuse them more than once or twice
Old Jul 17, 2007 | 08:14 PM
lude98SH's Avatar
Default Re: Replace main bolts (Missing Gears)
ok cool. Is it critical that i put the same bolt in the same hole ? I kept them together just in case i had to.
Old Jul 17, 2007 | 09:57 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">ok cool. Is it critical that i put the same bolt in the same hole ? I kept them together just in case i had to. </TD></TR></TABLE>
nope.
Old Jul 18, 2007 | 06:02 AM
preludestud11's Avatar
Default Re: Replace main bolts (Rosko)
just have people said already, i re-used mine, and i didnt have them in the same location. No problem so far after about 5,000 NA miles, and about 4,000 boosted.
91tegraRS
Apr 12, 2010 08:19 AM
killerpenguin21
Jul 25, 2006 06:18 PM
B18_Civic
Aug 19, 2005 07:16 PM
dumpeDc2
Nov 6, 2004 12:24 PM
85mm LS VTEC
May 19, 2004 07:57 PM
